◆ LoadExistingMultiAxis()
MultiAxis * LoadExistingMultiAxis ( int32_t motionSupervisorNumber)
Get/Create a MultiAxis object from one that already exists (previously setup) on the RMP motion controller firmware. This is the call RapidSetup uses to show previously created MultiAxis objects.
motionSupervisorNumberA motion supervisor index, should be >= AxisCount.
(MultiAxis*) A pointer to the MultiAxis specified.
You'll need to set the number of MotionSupervisors to a number greater than the Axis count. This should be done before any calls to AxisGet(), MultiAxisGet(), or LoadExistingMultiAxis().
Creation Methods Info
⚙️ Handling Errors
⚙️ Helper Functions
⚙️ Object Cleanup
MultiAxis::AxisAdd , MotionCountGet , MotionCountSet
Motion: Multi-Axis
/* This sample demonstrates both trapezoidal and S-curve point-to-point motion profiles for multi-axis motion.
The MultiAxis object coordinates the motion of multiple axes simultaneously.
Console.WriteLine("📜 MultiAxis Motion: Point to Point");
Console.WriteLine($"Axis Count: {controller.AxisCountGet()}");
Helpers.VerifyAxisCount(controller, minRequiredSampleAxisCount: 2, minRequiredSampleMultiAxisCount: 1);
// get axes
Helpers.CheckErrors(axis0);
Helpers.CheckErrors(axis1);
// get multiaxis (indexed by motion supervisor number, indexing starts at 0)
Helpers.CheckErrors(multi);
// remove any existing axes
multi.AxisRemoveAll();
// add axes to multiaxis
multi.AxisAdd(axis0);
multi.AxisAdd(axis1);
// Use MotionAttributeMaskOnSet and MotionAttributeMaskOffSet to enable/disable synchronization features
// Both SYNC_START and SYNC_END are enabled by default
// See our Motion: Point-to-Point documentation for more details
// multi.MotionAttributeMaskOffSet(RSIMotionAttrMask.RSIMotionAttrMaskSYNC_START);
// multi.MotionAttributeMaskOffSet(RSIMotionAttrMask.RSIMotionAttrMaskSYNC_END);
// prepare for motion
multi.Abort(); // stop any existing motion
multi.ClearFaults();
// Reset axes and position
axis0.PositionSet(0);
axis1.PositionSet(0);
// define motion parameters
double[] positions1 = [ 5, 10 ]; // first set of positions
double[] positions2 = [ 15, 15 ]; // second set of positions
double[] velocities1 = [ 10, 10 ]; // velocities for first move
double[] velocities2 = [ 10, 10 ]; // velocities for second move
double[] accelerations = [ 20, 20 ]; // accelerations for both axes
double[] decelerations = [ 20, 20 ]; // decelerations for both axes
double[] jerkPercent = [ 50, 50 ]; // jerk percent for s-curve motion
// move using s-curve motion profile
Console.WriteLine($"\nMove 1 (S-Curve): Positions = [{positions1[0]}, {positions1[1]}]");
multi.MoveSCurve(positions1, velocities1, accelerations, decelerations, jerkPercent);
multi.MotionDoneWait(); // wait for motion to complete
Console.WriteLine($"Axis 0 CommandPosition: {axis0.CommandPositionGet()} (expected: {positions1[0]})");
Console.WriteLine($"Axis 1 CommandPosition: {axis1.CommandPositionGet()} (expected: {positions1[1]})");
// move using trapezoidal motion profile
Console.WriteLine($"\nMove 2 (Trapezoidal): Positions = [{positions2[0]}, {positions2[1]}]");
multi.MoveTrapezoidal(positions2, velocities2, accelerations, decelerations);
Console.WriteLine($"Axis 0 CommandPosition: {axis0.CommandPositionGet()} (expected: {positions2[0]})");
Console.WriteLine($"Axis 1 CommandPosition: {axis1.CommandPositionGet()} (expected: {positions2[1]})");
Helpers.AbortMotionObject(multi);
Console.WriteLine("\nMulti-axis point-to-point motion complete.");
const int AXIS_1_INDEX
Definition _constants.cs:21
void AxisRemoveAll()
Point-to-point S-Curve Move.
void AxisAdd(Axis *axis)
Definition rsi.h:12018
