◆ HomeOffsetSet()
void HomeOffsetSet ( double offset)
During a master-based homing sequence (as configured by HomeMethodSet), the controller detects a specific physical event (like reaching a limit switch, detecting an index pulse, hitting a hard stop, etc.) which serves as the homing reference point.
This function, HomeOffsetSet, defines the position value (in UserUnits) that the axis coordinate system should report at the precise moment this reference event is detected.
The relationship is: Reported Axis Position = -offset when the reference event occurs.
By setting this offset, you establish the relationship between your logical user coordinate system (where zero or other key positions are) and the physical feature used for homing.
Example Use Cases:
  • Defining a Hard Stop Location: If you home to a physical hard stop and want that exact position to correspond to 50.0 UserUnits in your coordinate system, you would set offset = -50.0.
  • Aligning with an Index Pulse: If the homing method uses an encoder index pulse (Z signal) as the reference, setting offset = 0.0 would make the position zero precisely when the pulse is detected. Setting offset = 1.0 would make the position -1.0 when the pulse occurs.
  • Centering the Travel Range: If you home to one end of travel (e.g., a positive limit) and know the total travel range, you can set the offset to place zero in the middle. For example, homing to a positive limit representing the end of a 200-unit range, setting offset = -100.0 would make the limit position 100.0, placing zero at the midpoint.
This parameter directly sets the coordinate value at the reference point (negated). It does not necessarily induce a separate move after the reference is found, that is done with the Axis::Home(bool) 'Move to Zero' parameter, which performs a distinct move after homing and offset application.
offsetThe value such that -offset will be the axis position (in UserUnits) assigned when the homing reference event occurs.
Axis: Homing
// get rmp controller
// configure limit action
// execute homing routine
axis.Home();
// clean up
Set the slow home velocity.
Execute the homing routine.
Set the home velocity.
bool HomeStateGet()
Get the home state.
Definition rsi.h:6515
Definition rsienums.h:617
Definition rsienums.h:1199
Home(bool)
HomeMethodSet
Master-based homing diagrams.
axis-homing-master-based.cs.
