◆ HomeVelocitySet() [1/2]
void HomeVelocitySet ( double velocity)
HomeVelocitySet sets the velocity used in the Home routine.
velocityunits/second.
Axis: Homing
// get rmp controller
// configure limit action
// execute homing routine
axis.Home();
// clean up
Set the slow home velocity.
Execute the homing routine.
Set the home velocity.
bool HomeStateGet()
Get the home state.
Definition rsi.h:6515
Definition rsienums.h:617
Definition rsienums.h:1199
Home
RSIHomeStage
HomeVelocitySet(double) will set both RSIHomeStageSTAGE_ONE & RSIHomeStageSTAGE_TWO to support legacy customers.
Master-based homing diagrams.
axis-homing-master-based.cs.
