Motion: Point-to-Point
Learn how to use point-to-point motion commands in C#.
In this page:
📜 Absolute Motion
Learn how to move a single axis in Absolute Motion 📖 profile. Absolute motion accelerates at a constant rate until reaching the specified velocity, then decelerates at a constant rate when approaching the target position.
axis.MoveTrapezoidal(POSITION, VELOCITY, ACCELERATION, DECELERATION);
Source: axis-motion-point-to-point.cs
📜 S-Curve Motion
Learn how to move a single axis in an S-Curve Motion 📖 profile. S-curve motion provides smoother acceleration and deceleration with controlled jerk.
📜 Relative Motion
Learn how to move a single axis Relative Motion 📖 to its current position. Shows moving forward and then back using negative relative distance.
axis.MoveRelative(POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT);
// move back to start using negative relative motion
axis.MoveRelative(-POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT);
📜 Final Velocity Motion
Learn how to command motion with a Final Velocity Motion 📖 . Once the position is reached, the axis continues spinning at the specified final velocity.
axis.MoveSCurve(POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT, FINAL_VELOCITY); // axis continues at final velocity after reaching position
// wait until axis transitions to final velocity
while (axis.StatusBitGet(RSIEventType.RSIEventTypeMOTION_AT_VELOCITY) == false)
Thread.Sleep(100);
📜 Velocity Motion
Learn how to move a single axis at a specified Velocity Motion 📖 . The axis accelerates to the velocity and continues until explicitly stopped.
axis.MoveVelocity(VELOCITY, ACCELERATION); // move at constant velocity
📜 Velocity Motion via Analog Input
This sample app was created using the EL3002 Analog Input module. Please note that some variable values might changed based on your analog input module. The functionality used with many other Analog Input modules, not only Beckhoff's.
Learn more about the EL3XXX analog input modules from beckhoff. (https://www.beckhoff.com/english/ethercat/analog.htm)
/* This sample demonstrates how to control axis velocity dynamically using an analog input value.
The analog input value (0 to 65536 for a 16-bit input) is mapped to a velocity range.
This was created using the EL3002 Analog Input module but works with many other modules.
using System.Threading;
Console.WriteLine("📜 Axis Motion: Velocity via Analog Input");
const double ACCELERATION = 100;
const double MAX_VEL = 10;
const double MAX_ANALOG = 65536; // 16-bit analog input
const int RUN_TIME_SECONDS = 20; // how long to run the velocity control loop
// get phantom axis
Axis axis = controller.AxisGet(Constants.AXIS_1_INDEX);
// get node
Helpers.CheckErrors(node);
// configure axis
// print sample info
Console.WriteLine($"Max Speed = {MAX_VEL}");
Console.WriteLine($"Running for {RUN_TIME_SECONDS} seconds...\n");
// control velocity based on analog input
var startTime = DateTime.Now;
while ((DateTime.Now - startTime).TotalSeconds < RUN_TIME_SECONDS)
// get analog input value and normalize to 0.0 - 1.0
double analogValue = node.AnalogInGet(analogChannel: 0);
double normalizedValue = analogValue / MAX_ANALOG;
│ Analog Input Value Maps Linearly to Velocity │
│ Analog: 0 ............................ 65,536 │
│ Velocity: 0 ............................ MAX_VEL │
// map analog input linearly to velocity (0 to MAX_VEL)
double velocity = normalizedValue * MAX_VEL;
axis.MoveVelocity(velocity, ACCELERATION);
Thread.Sleep(1); // prevent cpu spin
const int AXIS_1_INDEX
Definition _constants.cs:21
Definition rsienums.h:621
