SingleAxisSyncOutputs.cpp
21
22#include "rsi.h" // Import our RapidCode Library.
23#include "SampleAppsHelper.h" // Import our SampleApp helper functions.
24#include "SampleApps.h"
25
26using namespace RSI::RapidCode; // Import the RapidCode namespace
27
29int SingleAxisSyncOutputs::Run()
30{
32 /* CONSTANTS */
33 // *NOTICE* The following constants must be configured before attempting to run with hardware.
34
35 // Axis configuration parameters
36 const int AXIS_COUNT = 1; // Specify how many axes you have.
37 const int AXIS_NUMBER = 0; // Specify which axis/motor to control.
38
39 const double USER_UNITS = 1048576; // Specify your counts per unit / user units. (the motor used in this sample app has 1048576 encoder pulses per revolution)
40
41 // IO configuration parameters
42 const int NODE_INDEX = 0; // Specify which EtherCat Node will be used
43 const int OUTPUT_INDEX = 0;
44
45 const int OUTPUT_ENABLE_ID = 2; // The motion element ID at which to set the output
46 const int OUTPUT_DISABLE_ID = 3; // The motion element ID at which to set the output
47
48 // Motion parameters
49 const int TOTAL_POINTS = 4; // total number of points
50 const int EMPTY_CT = -1; // Number of points that remains in the buffer before an e-stop
51 const double POSITIONS[] = { 0.25, 0.50, 0.75, 1.0 }; // These will be the streaming motion 5 positions.
52 const double TIMES[] = { 0.5, 1.0, 1.5, 2.0 }; // These will be the streaming motion 5 positions' time.
53
54 // To run with hardware, set the USE_HARDWARE flag to true AFTER you have configured the parameters above and taken proper safety precautions.
55 USE_HARDWARE = false;
56
57 // The rmpPath only needs to be set if the project directory is different than the rapid setup directory.
58 // *NOTICE* When setting the rmpPath, be sure to uncomment the rmpPath arguement in MotionController::CreateFromSoftware() in the Run() function.
59 char rmpPath[] = "C:\\RSI\\X.X.X\\"; // Insert the path location of the RMP.rta (usually the RapidSetup folder)
60
61 // Initialize MotionController class.
62 MotionController* controller = MotionController::CreateFromSoftware(/*rmpPath*/); // NOTICE: Uncomment "rmpPath" if project directory is different than rapid setup directory.
63 SampleAppsHelper::CheckErrors(controller); // [Helper Function] Check that the axis has been initialize correctly.
64
65 // Setup the controller for the appropriate hardware configuration.
66 if (USE_HARDWARE)
67 {
69 }
70 else
71 {
72 SampleAppsHelper::SetupControllerForPhantoms(controller, AXIS_COUNT, { AXIS_NUMBER });
73 }
74
75 try
76 {
77 Axis* axis = controller->AxisGet(AXIS_NUMBER); // Initialize Axis Class. (Use RapidSetup Tool to see what is your axis number)
78 SampleAppsHelper::CheckErrors(axis); // [Helper Function] Check that the axis has been initialize correctly.
79
80 axis->PositionSet(0); // Make sure motor starts at position 0 everytime.
81 axis->UserUnitsSet(USER_UNITS); // Change your user units.
82 axis->ErrorLimitActionSet(RSIAction::RSIActionNONE); // Set Error Limit Action.
83 axis->Abort(); // If there is any motion happening, abort it.
84 axis->ClearFaults(); // Clear faults.>
85 axis->AmpEnableSet(true); // Enable the motor.
86
87 // Set up the inputs
88 // Ensure the digital out is set low.
89 //IOPoint *output0 = IOPoint::CreateDigitalOutput(axis, RSIMotorGeneralIo.RSIMotorGeneralIo16); // Retrieve DOUT 1, Method 1: requires you know the io adress in memory, slightly faster
90 IOPoint* output0 = IOPoint::CreateDigitalOutput(controller->IOGet(NODE_INDEX), OUTPUT_INDEX); // Retrieve DOUT 1 Method 2: only need to know node index
91 output0->Set(false);
92
93 // Set up Sync Outputs
94 axis->StreamingOutputsEnableSet(true); // Enable streaming output.
95
96 // ENABLE the Sync Output(s)
97 axis->StreamingOutputAdd(output0, true, OUTPUT_ENABLE_ID); // This will turn DOUT1 High when the streaming motion reaches its 3rd motion point.
98 axis->StreamingOutputAdd(output0, false, OUTPUT_DISABLE_ID); // This will turn DOUT1 Low when the streaming motion reaches its 4th motion point.
99
100 // DISABLE the Sync Output(s)
101 //axis->StreamingOutputAdd(output0, false, outPutEnableID);
102
103 axis->MovePT(RSIMotionType::RSIMotionTypePT, POSITIONS, TIMES, TOTAL_POINTS, EMPTY_CT, false, true); // Start Streaming Motion
104 printf("Motion started. Waiting to complete.\n");
105
106 axis->MotionDoneWait(); // What for Streaming Motion to be done.
107 printf("Motion Complete. The outputs should have been set\n");
108
109 axis->StreamingOutputsEnableSet(false); // Disable Sync Outputs.
110 axis->AmpEnableSet(false); // Disable the motor.
111
112 }
113 catch (RsiError const& err)
114 {
115 printf("%s\n", err.text); // If there are any exceptions/issues this will be printed out.
116 return -1;
117 }
118 controller->Delete(); // Delete the controller as the program exits to ensure memory is deallocated in the correct order.
119 return 0;
121}
void Set(bool state)
@ RSIMotionTypePT
Definition rsienums.h:1089
@ RSIActionNONE
Definition rsienums.h:1166
