PathMotion.cs
47using RSI.RapidCode.dotNET; // Import our RapidCode Library.
48using NUnit.Framework;
49using System;
50using System.Linq;
51using System.Threading;
52
53#if DOXYGEN // RSI internal documentation use only
54using RSI.RapidCode;
56#endif
57
58
59[TestFixture]
60[Category("Software")]
61public class PathMotion : SampleAppTestBase
62{
63 [SetUp]
64 public void Setup()
65 {
66 jointsMultiAxis?.AxisRemoveAll();
67 }
68
69 [TearDown]
70 public void Teardown()
71 {
72 robot?.EStop();
73 robot?.MotionDoneWait();
74 robot?.ClearFaults();
75 Robot.RobotDelete(controller, robot);
76 robot = null;
77
78 jointsMultiAxis?.Abort();
79 Thread.Sleep(50);
80 jointsMultiAxis?.ClearFaults();
81 }
82
83 private void VerifyModel(KinematicModel model, LinearUnits expectedUnits, string expectedName)
84 {
85 var actualUnits = model.UnitsGet();
86 Assert.That(actualUnits, Is.EqualTo(expectedUnits), $"Expected model units to be '{expectedUnits}' but was '{actualUnits}' instead!");
87 var actualName = model.NameGet();
88 Assert.That(actualName, Is.EqualTo(expectedName), $"Expected model name to be '{expectedName}' but was '{actualName}' instead!");
89 }
90
91 [Test]
92 public void GantryPrimeAxis()
93 {
94 prime_axis = z_axis;
96 // We assume the axes have been confgured and homed properly prior this this program.
97
98 const string xLabel = "X-Axis";
99 const string yLabel = "Y-Axis";
100 const string primeLabel = "Y-Prime";
101
102 // Set the expected labels for each axis.
103 x_axis.UserLabelSet(xLabel);
104 y_axis.UserLabelSet(yLabel);
105 prime_axis.UserLabelSet(primeLabel);
106
107 // The joint index of each axis is the index within the MultiAxis object.
108 // "X-Axis" has joint index 0
109 // "Y-Axis" has joint index 1
110 // "Y-Prime" has joint index 2
111 Axis[] axes = new Axis[] { x_axis, y_axis, prime_axis };
112 jointsMultiAxis.AxesAdd(axes, axes.Length);
113
114 const LinearUnits units = LinearUnits.Millimeters;
115 const string modelName = "RSI_XY_Yp";
116 const double scaling = 1.0, offset = 0.0;
117 LinearModelBuilder builder = new LinearModelBuilder(modelName);
118 builder.UnitsSet(units);
119 builder.JointAdd(new LinearJointMapping(0, CartesianAxis.X) { ExpectedLabel = xLabel, Scaling = scaling, Offset = offset });
120 builder.JointAdd(new LinearJointMapping(1, CartesianAxis.Y) { ExpectedLabel = yLabel, Scaling = scaling, Offset = offset });
121 builder.JointAdd(new LinearJointMapping(2, CartesianAxis.Y) { ExpectedLabel = primeLabel, Scaling = scaling, Offset = offset });
122
123 // Create a Robot object where the y and y prime will be geared 1:1
124 const int motionFrameBufferSize = 50; // This is the minimum valid motion frame buffer size.
125 robot = Robot.RobotCreate(controller, jointsMultiAxis, builder, motionFrameBufferSize);
128
129 VerifyModel(robot.ModelGet(), units, modelName);
130 }
131
132 [Test, Timeout(Constants.MAX_TEST_TIME)]
133 public void SimplePathMotion()
134 {
136 // We assume the axes have been confgured and homed properly prior this this program.
137 const string xLabel = "X-Axis";
138 const string yLabel = "Y-Axis";
139 const string zLabel = "Z-Axis";
140 const string aLabel = "A-Axis";
141 const string bLabel = "B-Axis";
142 const string cLabel = "C-Axis";
143
144 // Set the expected labels for each axis.
145 x_axis.UserLabelSet(xLabel);
146 y_axis.UserLabelSet(yLabel);
147 z_axis.UserLabelSet(zLabel);
148 a_axis.UserLabelSet(aLabel);
149 b_axis.UserLabelSet(bLabel);
150 c_axis.UserLabelSet(cLabel);
151
152 // The joint index of each axis is the index within the MultiAxis object.
153 // "X-Axis" has joint index 0
154 // "Y-Axis" has joint index 1
155 // "Z-Axis" has joint index 2
156 // "A-Axis" has joint index 3
157 // "B-Axis" has joint index 4
158 // "C-Axis" has joint index 5
159 Axis[] axes = new Axis[] { x_axis, y_axis, z_axis, a_axis, b_axis, c_axis };
160 jointsMultiAxis.AxesAdd(axes, axes.Length);
161 jointsMultiAxis.ClearFaults();
162
163 const LinearUnits units = LinearUnits.Meters;
164 const string modelName = "RSI_XYZABC_Meters";
165 const double scaling = 1.0, offset = 0.0;
166 LinearModelBuilder builder = new LinearModelBuilder(modelName);
167 builder.UnitsSet(units);
168 builder.JointAdd(new LinearJointMapping(0, CartesianAxis.X) { ExpectedLabel = xLabel, Scaling = scaling, Offset = offset });
169 builder.JointAdd(new LinearJointMapping(1, CartesianAxis.Y) { ExpectedLabel = yLabel, Scaling = scaling, Offset = offset });
170 builder.JointAdd(new LinearJointMapping(2, CartesianAxis.Z) { ExpectedLabel = zLabel, Scaling = scaling, Offset = offset });
171 builder.JointAdd(new LinearJointMapping(3, CartesianAxis.Roll) { ExpectedLabel = aLabel, Scaling = scaling, Offset = offset });
172 builder.JointAdd(new LinearJointMapping(4, CartesianAxis.Pitch) { ExpectedLabel = bLabel, Scaling = scaling, Offset = offset });
173 builder.JointAdd(new LinearJointMapping(5, CartesianAxis.Yaw) { ExpectedLabel = cLabel, Scaling = scaling, Offset = offset });
174
175 // Create a Robot object with a multi axis containing all joints and the kinematic type
176 robot = Robot.RobotCreate(controller, jointsMultiAxis, builder, MotionController.AxisFrameBufferSizeDefault);
178
179 robot.PathAccelerationSet(1000); // UserUnits per sec sqd
180 robot.PathVelocitySet(50); // UserUnits per sec
181
183 robot.PathProgrammingModeSet(PathMode.Absolute);
184 robot.PathLine(new Pose(1, 1, 0));
185 robot.PathArc(new Pose(0, 2, 0), new Vector3d(0, 1, 0), RotationDirection.Clockwise);
186
187 jointsMultiAxis.ClearFaults();
188 jointsMultiAxis.AmpEnableSet(true);
189 robot.Run(); // Starts the motion. Calling with the false arguement for non blocking behavior
190 bool isRunning = robot.IsRunning();
192
193 VerifyModel(robot.ModelGet(), units, modelName);
194 }
195
196 [Test]
197 public void ChangingUnits()
198 {
200 // We assume the axes have been confgured and homed properly prior this this program.
201 const string xLabel = "X-Axis";
202 const string yLabel = "Y-Axis";
203 const string zLabel = "Z-Axis";
204 const string aLabel = "A-Axis";
205 const string bLabel = "B-Axis";
206 const string cLabel = "C-Axis";
207
208 // Set the expected labels for each axis.
209 x_axis.UserLabelSet(xLabel);
210 y_axis.UserLabelSet(yLabel);
211 z_axis.UserLabelSet(zLabel);
212 a_axis.UserLabelSet(aLabel);
213 b_axis.UserLabelSet(bLabel);
214 c_axis.UserLabelSet(cLabel);
215
216 // The joint index of each axis is the index within the MultiAxis object.
217 // "X-Axis" has joint index 0
218 // "Y-Axis" has joint index 1
219 // "Z-Axis" has joint index 2
220 // "A-Axis" has joint index 3
221 // "B-Axis" has joint index 4
222 // "C-Axis" has joint index 5
223 Axis[] axes = new Axis[] { x_axis, y_axis, z_axis, a_axis, b_axis, c_axis };
224 jointsMultiAxis.AxesAdd(axes, axes.Length);
225
226 const LinearUnits units = LinearUnits.Millimeters;
227 const string modelName = "RSI_XYZABC_Millimeters";
228 const double scaling = 1.0, offset = 0.0;
229 LinearModelBuilder builder = new LinearModelBuilder(modelName);
230 builder.UnitsSet(units);
231 builder.JointAdd(new LinearJointMapping(0, CartesianAxis.X) { ExpectedLabel = xLabel, Scaling = scaling, Offset = offset });
232 builder.JointAdd(new LinearJointMapping(1, CartesianAxis.Y) { ExpectedLabel = yLabel, Scaling = scaling, Offset = offset });
233 builder.JointAdd(new LinearJointMapping(2, CartesianAxis.Z) { ExpectedLabel = zLabel, Scaling = scaling, Offset = offset });
234 builder.JointAdd(new LinearJointMapping(3, CartesianAxis.Roll) { ExpectedLabel = aLabel, Scaling = scaling, Offset = offset });
235 builder.JointAdd(new LinearJointMapping(4, CartesianAxis.Pitch) { ExpectedLabel = bLabel, Scaling = scaling, Offset = offset });
236 builder.JointAdd(new LinearJointMapping(5, CartesianAxis.Yaw) { ExpectedLabel = cLabel, Scaling = scaling, Offset = offset });
237
238 // Create a Robot object with a multi axis containing all joints and the kinematic type
239 robot = Robot.RobotCreate(controller, jointsMultiAxis, builder, MotionController.AxisFrameBufferSizeDefault);
241
242 //NOTE: to use the above kinematic model you must have a gantry (linear 1:1 kinematics) and each linear axis must have its user units scaled to millimeters
243
244 robot.PathAccelerationSet(10); //Sets the PATH acceleration to 10 Millimeters per second sqd
245 robot.PathVelocitySet(10); //Sets the PATH velocity to 10 Millimeters per second
246
247 Console.WriteLine(robot.PathUnitsGet());//This will print the int value for the enum for Millimeters
248
249 robot.PathUnitsSet(LinearUnits.Centimeters);
250
251 robot.PathAccelerationSet(10); //Sets the PATH acceleration to 10 Centimeters per second sqd
252 robot.PathVelocitySet(10); //Sets the PATH velocity to 10 Centimeters per second
253
254 Console.WriteLine(robot.PathLinearScalingGet());//Will print the scale factor to convert CM to MM
255
256 //NOTE: you can also set this directly. Doing so will result in PathUnitsGet() returning NONE
258
259 VerifyModel(robot.ModelGet(), units, modelName);
260 }
261
262 public void PathPoint()
263 {
265 const ulong frameCount = 500;
266 ulong totalFrames = frameCount;
267 ulong startFrame = 0;
268
269 while (totalFrames == frameCount)
270 {
271 RapidVectorRobotPosition positions = robot.PathPlannedPositionsGet(startFrame, frameCount);
272 totalFrames = positions.Size();
273
274 foreach (RobotPosition position in positions.ToArray())
275 {
276 Pose pose = position.Pose;
277 Vector3d spatial = pose.Position;
278 double xCoord = spatial.X, yCoord = spatial.Y, zCoord = spatial.Z;
279 Quaternion orientation = pose.Orientation;
280 }
281
282 //Add code here to create the rendering out of the positions you have collected.
283 //Use your prefered 3d library.
284 //Example:
285 //vector3 = new Vector3D(xPosition, yPosition, zPosition);
286 //linePositions.Add(Vector3DToVector3(vector3));
287
288 startFrame += totalFrames;
289 }
291 }
292}
Definition rsi.h:5706
void UnitsSet(LinearUnits units)
Vector3d Position
The position component of the Pose.
Quaternion Orientation
The orientation component of the Pose.
Quaternion for representing rotations.
uint64_t MotionDoneWait()=0
RapidVector< RobotPosition > PathPlannedPositionsGet(uint64_t startFrame, uint64_t frameCount)=0
Get Positions (see RobotPosition) representing the planned motion in cartesian space that will happen...
void PathVelocitySet(double unitsPerSecond)=0
Sets the target linear cartesian velocity for each move (UserUnits/second).
bool IsRunning()=0
Returns whether or not the robot is in motion (from executor or other source). Can be used to determi...
double PathLinearScalingGet() const =0
Gets scaling between input to path motion and output of path motion to the kinematic model.
void PathAccelerationSet(double unitsPerSecondSquared)=0
Sets the target acceleration for the machine (UserUnits/second^2). Should be set appropriately based ...
LinearUnits PathUnitsGet() const =0
Gets the units of path motion.
void PathArc(const Pose &target, double radius, RotationDirection direction)=0
Appends an arc on to the current on the PathPlaneGet() plane XY by default.
void PathUnitsSet(LinearUnits units)=0
Defines the units Cartesian Path Motion is in.
void PathLine(const Pose &target)=0
void EStop()=0
void PathProgrammingModeSet(PathMode mode)=0
Sets the programming mode (Relative/Absolute).
void Run()=0
Run the loaded path lines/arcs. The behavior is non-blocking. Use Robot.MotionDoneWait() to block.
void ClearFaults()=0
Delete a Robot.
A representation of the robot containing the Pose and the positions of the free axes.
RSI::RapidCode::Cartesian::Pose Pose
The Robot's Pose.
Vector3d is used for three-dimensional points and vectors.
Definition rsi.h:854
Definition rsi.h:800
void AxisRemoveAll()
PathMode
Motion types. For G-code use and Cartesian path motion.
CartesianAxis
RotationDirection
Rotational directions about an axis.
LinearUnits
The Cartesian namespace.
