47using RSI.RapidCode.dotNET;
51using System.Threading;
61public class PathMotion : SampleAppTestBase
70 public void Teardown()
78 jointsMultiAxis?.
Abort();
85 var actualUnits = model.UnitsGet();
86 Assert.That(actualUnits, Is.EqualTo(expectedUnits), $
"Expected model units to be '{expectedUnits}' but was '{actualUnits}' instead!");
87 var actualName = model.NameGet();
88 Assert.That(actualName, Is.EqualTo(expectedName), $
"Expected model name to be '{expectedName}' but was '{actualName}' instead!");
92 public void GantryPrimeAxis()
98 const string xLabel =
"X-Axis";
99 const string yLabel =
"Y-Axis";
100 const string primeLabel =
"Y-Prime";
111 Axis[] axes =
new Axis[] { x_axis, y_axis, prime_axis };
112 jointsMultiAxis.
AxesAdd(axes, axes.Length);
115 const string modelName =
"RSI_XY_Yp";
116 const double scaling = 1.0, offset = 0.0;
124 const int motionFrameBufferSize = 50;
125 robot =
Robot.
RobotCreate(controller, jointsMultiAxis, builder, motionFrameBufferSize);
129 VerifyModel(robot.
ModelGet(), units, modelName);
132 [Test, Timeout(Constants.MAX_TEST_TIME)]
133 public void SimplePathMotion()
137 const string xLabel =
"X-Axis";
138 const string yLabel =
"Y-Axis";
139 const string zLabel =
"Z-Axis";
140 const string aLabel =
"A-Axis";
141 const string bLabel =
"B-Axis";
142 const string cLabel =
"C-Axis";
159 Axis[] axes =
new Axis[] { x_axis, y_axis, z_axis, a_axis, b_axis, c_axis };
160 jointsMultiAxis.
164 const string modelName =
"RSI_XYZABC_Meters";
165 const double scaling = 1.0, offset = 0.0;
193 VerifyModel(robot.
197 public void ChangingUnits()
201 const string xLabel =
"X-Axis";
202 const string yLabel =
"Y-Axis";
203 const string zLabel =
"Z-Axis";
204 const string aLabel =
"A-Axis";
205 const string bLabel =
"B-Axis";
206 const string cLabel =
"C-Axis";
223 Axis[] axes =
224 jointsMultiAxis.
227 const string modelName =
"RSI_XYZABC_Millimeters";
228 const double scaling = 1.0, offset = 0.0;
259 VerifyModel(robot.
262 public void PathPoint()
265 const ulong frameCount = 500;
266 ulong totalFrames = frameCount;
267 ulong startFrame = 0;
269 while (totalFrames == frameCount)
272 totalFrames = positions.Size();
278 double xCoord = spatial.
X, yCoord = spatial.
Y, zCoord = spatial.
Z;
288 startFrame += totalFrames;
void UnitsSet(LinearUnits units)
Vector3d Position
The position component of the Pose.
Quaternion Orientation
The orientation component of the Pose.
Quaternion for representing rotations.
uint64_t MotionDoneWait()=0
RapidVector< RobotPosition > PathPlannedPositionsGet(uint64_t startFrame, uint64_t frameCount)=0
Get Positions (see RobotPosition) representing the planned motion in cartesian space that will happen...
void PathVelocitySet(double unitsPerSecond)=0
Sets the target linear cartesian velocity for each move (UserUnits/second).
bool IsRunning()=0
Returns whether or not the robot is in motion (from executor or other source). Can be used to determi...
double PathLinearScalingGet() const =0
Gets scaling between input to path motion and output of path motion to the kinematic model.
void PathAccelerationSet(double unitsPerSecondSquared)=0
Sets the target acceleration for the machine (UserUnits/second^2). Should be set appropriately based ...
LinearUnits PathUnitsGet() const =0
Gets the units of path motion.
void PathArc(const Pose &target, double radius, RotationDirection direction)=0
Appends an arc on to the current on the PathPlaneGet() plane XY by default.
void PathUnitsSet(LinearUnits units)=0
Defines the units Cartesian Path Motion is in.
void PathLine(const Pose &target)=0
void EStop()=0
void PathProgrammingModeSet(PathMode mode)=0
Sets the programming mode (Relative/Absolute).
void Run()=0
Run the loaded path lines/arcs. The behavior is non-blocking. Use Robot.MotionDoneWait() to block.
void ClearFaults()=0
Delete a Robot.
A representation of the robot containing the Pose and the positions of the free axes.
RSI::RapidCode::Cartesian::Pose Pose
The Robot's Pose.
Vector3d is used for three-dimensional points and vectors.
double Z
The Z coordinate.
double X
The X coordinate.
double Y
The Y coordinate.
void AxisRemoveAll()
PathMode
Motion types. For G-code use and Cartesian path motion.
CartesianAxis
RotationDirection
Rotational directions about an axis.
LinearUnits
