InputOutput.cs
Attention
See the following Concept pages for a detailed explanation of this sample: Dedicated IO, IOPoint, PDO vs. SDO Streaming Motion Sync Outputs.
using NUnit.Framework;
using System;
#if DOXYGEN
// needed for docs generation
#else
// needed for project to compile (NetworkNode alias maps to RapidCodeNetworkNode for Doxygen)
using NetworkNode = RSI.RapidCode.dotNET.RapidCodeNetworkNode;
#endif
[TestFixture]
[Category("Software")]
class InputOutput : SampleAppTestBase
[Ignore("Needs a network with a real node to run, but we want the snippet for docs. At least it's compiled!")]
public void GeneralPurposeIO()
Assert.DoesNotThrow(() =>
const int nodeIndex = 0;
const int digitalInIndex = 0;
const int digitalOutIndex = 0;
const int analogIndex = 0;
// get node
NetworkNode node = controller.NetworkNodeGet(nodeIndex);
// digital io
bool dIn = node.DigitalInGet(digitalInIndex);
bool dOut = node.DigitalOutGet(digitalOutIndex);
node.DigitalOutSet(digitalOutIndex, true);
// analog io
int aIn = node.AnalogInGet(analogIndex);
int aOut = node.AnalogOutGet(analogIndex);
node.AnalogOutSet(analogIndex, 1234);
public void DedicatedIO()
// Retrieve dedicated inputs with generic and specific function.
axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInLIMIT_HW_NEG),
axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInLIMIT_HW_POS),
axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInHOME),
axis.HomeSwitchGet());
axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInAMP_FAULT),
axis.AmpFaultGet());
axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInAMP_ACTIVE),
axis.AmpEnableGet());
public void NetworkInputsAndOutputs()
// Get Input Values
int inputCount = controller.NetworkInputCountGet(); // Get number of Network Inputs (PDOs)
int size = controller.NetworkInputBitSizeGet(i); // Read Input BitSize
int offset = controller.NetworkInputBitOffsetGet(i); // Read Input BitOffset
string name = controller.NetworkInputNameGet(i); // Read Input Name
UInt64 value = controller.NetworkInputValueGet(i); // Read Input Value
// Get Output Values
int outputCount = controller.NetworkOutputCountGet(); // Get number of Network Outputs (SDOs)
int size = controller.NetworkOutputBitSizeGet(i); // Read Output BitSize
int offset = controller.NetworkOutputBitOffsetGet(i); // Read Output BitOffset
string name = controller.NetworkOutputNameGet(i); // Read Output Name
UInt64 value = controller.NetworkOutputSentValueGet(i); // Read Output Value
//TODO expand examples once iopoint is expanded.
[Test]
public void IOPoints()
const int NODE_INDEX = 0; // The EtherCAT Node we will be communicating with
const int OUTPUT_INDEX = 0; // The PDO Index in that Node
IOPoint output0 = IOPoint.CreateDigitalOutput(controller.NetworkNodeGet(NODE_INDEX), OUTPUT_INDEX); // Automatically gets the memory index of a specified node and input index
output0.Set(false);
controller.SampleWait(1);
Assert.That(output0.Get(), Is.False, "The getter function should return a value equal to false");
[Test]
public void IOPointUserBuffer()
const int OUTPUT_INDEX = 1; // The PDO Index in that Node
IOPoint input0 = IOPoint.CreateDigitalInput(controller, userBufferAddress, INPUT_INDEX); // Automatically gets the memory index of a specified node and input index
IOPoint output0 = IOPoint.CreateDigitalOutput(controller, userBufferAddress, OUTPUT_INDEX); // Automatically gets the memory index of a specified node and input index
//---ACT/ASSERT---
output0.Set(false);
output0.Set(true);
Assert.That(output0.Get(), Is.True, "The getter function should return a value equal to true");
controller.MemorySet(input0.AddressGet(), 0);
Assert.That(input0.Get(), Is.False, "The getter function should return a value equal to false");
Assert.That(input0.Get(), Is.True, "The getter function should return a value equal to true");
[Test]
public void SingleAxisSyncOutputs()
const int EMPTY_CT = -1; // Number of points that remains in the buffer before an e-stop
const int OUTPUT_INDEX = 0; // This is the index of the digital output that will go active when the user limit triggers.
double[] positions = { 1.0, 2.0, 3.0, 4.0 }; // These will be the streaming motion 5 positions.
double[] times = { 0.5, 0.1, 0.2, 0.4 }; // These will be the streaming motion 5 positions' time.
int outputEnableID = 2; // The motion element ID at which to set the output
int outputDisableID = 3; // The motion element ID at which to set the output
// Set up the inputs
// IOPoint output0 = IOPoint.CreateDigitalOutput(axis, RSIMotorGeneralIo.RSIMotorGeneralIo16); // Retrieve DOUT 1, Method 1: requires you know the io adress in memory, slightly faster
IOPoint output0 = IOPoint.CreateDigitalOutput(controller.NetworkNodeGet(NODE_INDEX), OUTPUT_INDEX); // Retrieve DOUT 1 Method 2: only need to know node index
output0.Set(false); // Set the output low
// Set up Sync Outputs
axis.StreamingOutputsEnableSet(true); // Enable streaming output.
// ENABLE the Sync Output(s)
axis.StreamingOutputAdd(output0, true, outputEnableID); // This will turn DOUT1 High when the streaming motion reaches its 3rd motion point.
axis.StreamingOutputAdd(output0, false, outputDisableID); // This will turn DOUT1 Low when the streaming motion reaches its 4th motion point.
// DISABLE the Sync Output(s)
// axis.StreamingOutputAdd(output0, false, outPutEnableID);
axis.MovePT(RSIMotionType.RSIMotionTypePT, positions, times, TOTAL_POINTS, EMPTY_CT, false, true); // Start Streaming Motion
while (!axis.MotionDoneGet())
if (axis.MotionIdExecutingGet() > outputEnableID && axis.CommandPositionGet() < outputEnableID)
Assert.That(output0.Get(), Is.EqualTo(true), "The output should be triggered");
Assert.That(output0.Get(), Is.EqualTo(false), "The output should NOT be triggered");
axis.StreamingOutputsEnableSet(false); // Disable Sync Outputs.
axis.AmpEnableSet(false); // Disable the motor.
double CommandPositionGet()
bool AmpEnableGet()
bool HomeSwitchGet()
bool PositiveLimitGet()
uint16_t MotionIdExecutingGet()
bool NegativeLimitGet()
bool AmpFaultGet()
bool DedicatedInGet(RSIMotorDedicatedIn motorDedicatedInNumber)
Read a digital input.
void Set(bool state)
bool Get()
Definition rsi.h:11559
NetworkNode * NetworkNodeGet(int32_t nodeNumber)
NetworkNodeGet returns a pointer to a RapidCodeNetworkNode object using its node number and initializ...
Sets a PDO output directly.
int32_t NetworkInputBitOffsetGet(int32_t index)
uint64_t NetworkOutputSentValueGet(int32_t index)
Gets the value sent out over EtherCAT.
Get the name of a PDO output.
int32_t NetworkOutputBitOffsetGet(int32_t index)
Get the raw PDO offset for an output.
void DigitalOutSet(int32_t digitalOutNumber, bool state)
Set the state of a digital output.
bool DigitalInGet(int32_t digitalInNumber)
Get the state of a digital input.
int32_t AnalogInGet(int32_t analogChannel)
bool DigitalOutGet(int32_t digitalOutNumber)
Get the state of a digital output.
int32_t AnalogOutGet(int32_t analogChannel)
Get the value of an analog output.
void AnalogOutSet(int32_t analogChannel, int32_t analogValue)
Set the value of an analog output.
Represents an EtherCAT node / SubDevice (Drive, I/O Block, etc) on the network. This class provides a...
Definition rsi.h:3854
bool MotionDoneGet()
RSIMotionType
Definition rsienums.h:1038
RSIMotorDedicatedIn
Definition rsienums.h:889
