Run a sample app on eRMP
Create C++ RapidCodeRT Hello World project that runs on eRMP.
🔹 RMP INtime: Run a RapidCodeRT app
The tutorial assumes you have INtime and Visual Studio properly installed on a Windows PC
  1. Create your application using the INtime Application Wizard Image
  2. Configure it to run on your eRMP Image
  3. Set the console output to run on your local machine run C:\Program Files (x86)\INtime\bin\stealconsoleio.exe Image
  4. Test and confirm that you can run a HelloWorld program on the remote PC and get the output on your local pc. Image
  5. Configure your C++ program to be able to run RMP motion controller.
    1. Add C:\\RSI\X.X.X\include and $(INtime)rt\include\cpp20 to your "Additional INclude Directories" Image
    2. Add
      RSIAPP
      __INTIME_CPP20
      _SILENCE_ALL_CXX17_DEPRECATION_WARNINGS
      _SILENCE_BOGUS_WARNINGS
      _HAS_NAMESPACE
      to your "Preprocessor Definitions"
    3. Add C:\RSI\X.X.X\lib\rt to "Additional Library Directories". Image
    4. Add RapidCodeRT.lib rt.lib pcibus.lib netlib.lib clib.lib vshelper17.lib to "Additional Dependencies". Image
      For Additional Dependencies please see:
      INtime documentation
    5. Add your rsi.lic to your eRMP
      1. Configure your eRMP for FTP file transfer
      2. Transfer rsi.lic to the root folder of your eRMP. Image
      3. Create a simple program to run on your eRMP. This example program will spin a phantom axis.
#include <iostream>
using namespace RSI::RapidCode;
static void CheckErrors(RapidCodeObject* rsiObject)
RsiError* err;
err = rsiObject->ErrorLogGet();
printf("%s\n", err->text);
static void StartTheNetwork(MotionController* controller)
// Initialize the Network
if (controller->NetworkStateGet() != RSINetworkState::RSINetworkStateOPERATIONAL) // Check if network is started already.
controller->NetworkStart(); // If not. Initialize The Network. (This can also be done from RapidSetup Tool)
if (controller->NetworkStateGet() != RSINetworkState::RSINetworkStateOPERATIONAL) // Check if network is started again.
int messagesToRead = controller->NetworkLogMessageCountGet(); // Some kind of error starting the network, read the network log messages
std::cout << "Expected OPERATIONAL state but the network did not get there." << std::endl;
//throw new RsiError(); // Uncomment if you want your application to exit when the network isn't operational. (Comment when using phantom axis)
std::cout << "Network Started" << std::endl;
MotionController* controller = MotionController::CreateFromSoftware(nullptr, "NodeB");
CheckErrors(controller);
printf("Hello, World!\n");
printf("Serial Number: %d", controller->SerialNumberGet());
try {
Axis* axis = controller->AxisGet(0); // Initialize Axis class
CheckErrors(axis);
axis->ClearFaults();
axis->AmpEnableSet(true);
axis->MoveRelative(100);
while (!axis->MotionDoneGet()) {
printf("%lf", axis->CommandPositionGet());
return 0;
printf("\n%s\n", e.what());
double CommandPositionGet()
Set the motor type.
bool MotionDoneGet()
int32_t ErrorLogCountGet()
Definition rsi.h:180
Definition rsi.h:111
@ RSINetworkStateOPERATIONAL
Definition rsienums.h:626
@ RSIActionNONE
Definition rsienums.h:1257
@ RSIMotorTypePHANTOM
Definition rsienums.h:1455
Definition helpers.h:87
