strong |
| Enumerator | |
| RSIControllerAddressTypeSAMPLE_COUNTER | Sample Counter. |
| RSIControllerAddressTypeSIGNATURE | Signature word. |
| RSIControllerAddressTypeUSER_BUFFER | First location in User Buffer. |
| RSIControllerAddressTypeRECORDER_BUFFER_POINTER | Pointer to the RecorderBuffer. |
| RSIControllerAddressTypeLIMIT_ENABLED_MASK | first 32-bits of LimitEnalbedMask |
| RSIControllerAddressTypeUSERLIMIT_STATUS | UserLimit status (must specify object index) |
| RSIControllerAddressTypeFRAME_SEND_RECEIVE_MICROSECONDS | programmable delay for packet send/receive (200µs default) |
| RSIControllerAddressTypeCOMPENSATOR_OUTPUT_TYPE | used to configure a compensator for single or additive output |
| RSIControllerAddressTypeCOMPENSATOR_COMPENSATOR_VALUE | the output of just that compensator no additive compensators |
| RSIControllerAddressTypeFIRMWARE_TIMING_DELTA | the latest time delta between the current RMP sample and the previous (microseconds) |
| RSIControllerAddressTypeNETWORK_TIMING_DELTA | the latest time delta between the current network packet send time and the previous (microseconds). MotionController::NetworkTimingEnableSet must be enabled |
| RSIControllerAddressTypeNETWORK_TIMING_RECEIVE_DELTA | the latest time delta between the current network packet receive time and the previous (microseconds). MotionController::NetworkTimingEnableSet must be enabled |
| RSIControllerAddressTypeMATHBLOCK_PROCESS_VALUE | the processed value of a math block (must specify object index) |
| RSIControllerAddressTypeFIRMWARE_NULL_INPUT | the null input value for the RMP firmware (used for restoring firmware input pointers to default) |
| RSIControllerAddressTypeFIRMWARE_NULL_OUTPUT | the null output value for the RMP firmware ( used for restoring firmware output pointers to default) |
| RSIControllerAddressTypeNETWORK_CLOCK_ENABLE | enable the Clock error collection feature 0 - Disabled 1 - Enabled |
| RSIControllerAddressTypeNETWORK_CLOCK_REFERENCE_ERROR_NS | error as determined between Ideal timestamp and Reference Clock timestamp (includes drift and jitter). |
| RSIControllerAddressTypeNETWORK_CLOCK_ADJUSTMENT_NS | adjustment value used for clock synchronization. |
| RSIControllerAddressTypeNETWORK_CLOCK_LINUX_ADJUSTMENT_NS | correction value used by linux. |
| RSIControllerAddressTypeNETWORK_CLOCK_INTIME_RELOAD_VALUE | hardware ticks between Intime kernel cycles. |
| RSIControllerAddressTypeNETWORK_CLOCK_MAX_RELOAD_VALUE_DELTA | max change to Intime Reload value per filter depth cycle. |
| RSIControllerAddressTypeNETWORK_CLOCK_FILTER_DEPTH | Filter Depth used by the clock alignment function. |
| RSIControllerAddressTypeNETWORK_CLOCK_KP | scaling factor for clock synchronization. |
| RSIControllerAddressTypeNETWORK_CLOCK_KI | scaling factor for clock synchronization. |
| RSIControllerAddressTypeNETWORK_CLOCK_KD | scaling factor for clock synchronization. |
Definition at line 405 of file rsienums.h.
