◆ RSINetworkSyncGroupState
enum class RSINetworkSyncGroupState
strong
Reported as the State field of MotionController::NetworkSyncGroupStatusGet, and recordable via RSIControllerAddressTypeNETWORK_SYNC_GROUP_STATE. The state is driven by the group's cyclic Working Counter every network sample, so DEGRADED and ABSENT assert within a few samples of the fault. See Sync Groups for the full concept (configuration workflow, monitoring, and recovery).
MotionController::NetworkSyncGroupStatus, MotionController::NetworkSyncGroupRecover, Axis::SyncGroupFaultActionSet
Enumerator
RSINetworkSyncGroupStateUNUSED
Sync group slot is not in use (no nodes assigned, or the network has not been started).
RSINetworkSyncGroupStateOPERATIONAL
All group nodes operational; group WKC matches expected (healthy, DataValid true).
RSINetworkSyncGroupStateDEGRADED
Tolerated WKC mismatch: members responding but at least one not in OP, or only some members responding (partial). Group inputs are frozen at last-good values (DataValid false). Recoverable in place with MotionController::NetworkSyncGroupRecover.
RSINetworkSyncGroupStateRECOVERING
A recovery operation (MotionController::NetworkSyncGroupRecover) is in progress for this group. If recovery fails, the prior state is restored.
RSINetworkSyncGroupStateABSENT
No member of the group is responding on the wire (physically disconnected or unpowered). Reconnect the hardware first: the group returns to DEGRADED when members respond again, then recover. A power-cycled member requires a full network restart.
Definition at line 692 of file rsienums.h.
