11.0.5
UserUnitsSet()
void UserUnitsSet
double
countsPerUserUnit
Allows you to change your default units from encoder counts to some other unit by supplying the number of encoder counts in said "User Unit."
countsPerUserUnit
The number of Encoder Counts in desired User Unit
Axis: Configuration
// Define counts per unit (user units)
// set
axis.
UserUnitsSet
Constants
AXIS_0_USER_UNITS
axis.
ErrorLimitTriggerValueSet
(1);
// Position error limit trigger (see support page)
// get
double
userUnits = axis.
UserUnitsGet
Go to axis screen->Motion and Tuning. In the image below, UserUnitsSet sets the value in the Counts per Unit box shown in the Motion Parameters box. It is currently set to 1 which means units are in counts.
UserUnitsGet
MotionHoldReleasedBySoftwareAddress.cpp
MultiaxisMotion.cpp
PVTmotionMultiAxis.cpp
PathMotion.cpp
SingleAxisSyncOutputs.cpp
SyncOutputWithMotion.cpp
UpdateBufferPoints.cpp
_helpers.cs
_setup.cs
axis-config-userunits.cs
axis-configuration.cpp
axis-motion-hold-via-address.cs
basic-template.cs
, and
compensator-single-axis.cs
1.15.0
