◆ HomeMethodGet()
RSIHomeMethod HomeMethodGet ( )
HomeMethodGet Gets the method to be used for homing.
A ::RSIHomeMethod value.
Axis: Homing
// get rmp controller
// configure limit action
// execute homing routine
axis.Home();
// clean up
Set the slow home velocity.
Execute the homing routine.
Set the home velocity.
bool HomeStateGet()
Get the home state.
Definition rsi.h:6515
Definition rsienums.h:617
Definition rsienums.h:1199
Home
Master-based homing diagrams.
