◆ HomeSlowVelocitySet()
void HomeSlowVelocitySet ( double velocity)
HomeSlowVelocitySet sets the velocity used for final homing.
velocityunits/second.
Axis: Homing
// get rmp controller
// configure limit action
// execute homing routine
axis.Home();
// clean up
Set the slow home velocity.
Execute the homing routine.
Set the home velocity.
bool HomeStateGet()
Get the home state.
Definition rsienums.h:621
Definition rsienums.h:1256
Deprecated. Use HomeVelocitySet(RSIHomeStageSTAGE_THREE, targetVelocity) instead.
axis-homing-master-based.cs.
