RandomWalk.cpp
10#include "SampleAppsHelper.h" // Import our helper functions.
11#include "rsi.h" // Import our RapidCode Library.
12
13#include "RTTasksHelpers.h" // Import our helper functions for RTTasks
14#include "rttask.h" // Import the RTTask library
15
16#include <iostream>
17#include <memory>
18#include <optional>
19#include <thread>
20#include <chrono>
21
22using namespace RSI::RapidCode; // Import the RapidCode namespace
23using namespace RSI::RapidCode::RealTimeTasks; // Import the RealTimeTasks namespace
24
25int main()
26{
27 const std::string SAMPLE_APP_NAME = "Real-Time Tasks: Random Walk";
28
29 // Print a start message to indicate that the sample app has started
30 SampleAppsHelper::PrintHeader(SAMPLE_APP_NAME);
31
32 /* CONSTANTS */
33 // *NOTICE* The following constants must be configured before attempting to run with hardware.
34 const int NUM_AXES = 1; // The number of axes to configure, default is 0 for this template
35 const int TIMEOUT_MS = 5000; // Timeout for waiting for the task to execute once
36
37 /* RAPIDCODE INITIALIZATION */
38
39 // Create the controller
41 MotionController *controller = MotionController::Create(&params);
42
43 std::optional<RTTaskManager> manager;
44
45 int exitCode = -1; // Set the exit code to an error value.
46 try
47 {
48 // Prepare the controller as defined in SampleAppsHelper.h depending on the configuration
50 SampleAppsHelper::SetupController(controller, NUM_AXES);
51
52 /* SET CONTROLLER OBJECT COUNTS HERE*/
53 // Normally you would set the number of axes here, but for samples that is handled in the SampleAppsHelper::SetupController function
54 // controller->AxisCountSet(NUM_AXES);
55
57 // Configure the axis
58 Axis *axis = controller->AxisGet(0);
60 axis->PositionSet(0);
61 axis->AmpEnableSet(true);
62
63 // Create the task manager
64 RTTaskManagerCreationParameters parameters = RTTaskHelper::GetTaskManagerCreationParameters();
65 std::cout << "Creating task manager..." << std::endl;
66 manager = RTTaskManager::Create(parameters);
67 SampleAppsHelper::CheckErrors(&manager.value());
68
69 // Call the initialization task to initialize the global variables and get pointers to RapidCode objects
70 // in the RTTaskFunctions library. This needs to be called before any task that uses RapidCode objects.
71 RTTaskHelper::InitializeRTTaskObjects(manager.value());
72
73 // Tell the task manager the name of the function to run as a task, the name
74 // of the library that contains the function, and the directory where the
75 // library is located. The RandomWalk function is defined in the RTTaskFunctions library.
76 // It moves the axis back and forth based on std::rand().
77 std::cout << "Submitting task..." << std::endl;
78 RTTaskCreationParameters params("RandomWalk");
80 params.Period = 5;
81 RTTask task = manager->TaskSubmit(params);
82
83 // Wait for the task to run for a bit
84 task.ExecutionCountAbsoluteWait(50, 500);
85
86 // Get the counter global tag to see if the task ran correctly
87 std::cout << "Getting counter global tag..." << std::endl;
88 FirmwareValue counter = manager->GlobalValueGet("counter");
89 if (counter.Int64 <= 0)
90 {
91 // The task did not run correctly
92 exitCode = -1;
93 std::cout << "Counter is not greater than 0. The task did not run correctly." << std::endl;
94 }
95 else
96 {
97 // The task ran correctly
98 exitCode = 0;
99 std::cout << "Counter: " << counter.Int64 << std::endl;
100 }
101
102 // The average global tag is the position the axis should be at if the RandomWalk task is working correctly
103 FirmwareValue average = manager->GlobalValueGet("average");
104 std::cout << "Average: " << average.Double << std::endl;
105
106 // Print the final axis position
107 std::cout << "Axis position: " << axis->CommandPositionGet() << std::endl;
108
109 task.Stop();
110 axis->MotionDoneWait(TIMEOUT_MS); // The axis might still be moving from the task, so wait for it to finish
111 axis->AmpEnableSet(false);
113 }
114 catch (const std::exception& e)
115 {
116 std::cerr << e.what() << std::endl;
117 }
118
119 // Shutdown the task manager firmware process
120 if (manager.has_value())
121 {
122 manager->Shutdown();
123 }
124
125 // Clean up the controller and any other objects as needed
126 SampleAppsHelper::Cleanup(controller);
127
128 // Delete the controller as the program exits to ensure memory is deallocated in the correct order
129 controller->Delete();
130
131 // Print a message to indicate the sample app has finished and if it was successful or not
132 SampleAppsHelper::PrintFooter(SAMPLE_APP_NAME, exitCode);
133
134 return exitCode;
135}
double CommandPositionGet()
Definition rsi.h:5870
Definition rsi.h:800
int32_t MotionDoneWait()
Definition rttask.h:435
static RTTaskManager Create(const RTTaskManagerCreationParameters &parameters)
Create a new RTTaskManager instance.
The RealTimeTasks namespace.
Definition rsi.h:866
Definition rttask.h:126
Definition rttask.h:140
Definition rttask.h:320
Definition rsi.h:468
double Double
Definition rsi.h:477
