PointToPoint.cpp
12#include <cmath>
13
14#include "SampleAppsHelper.h" // Import our helper functions.
15#include "rsi.h" // Import our RapidCode Library.
16
17using namespace RSI::RapidCode; // Import the RapidCode namespace
18
19// Helper function to wait for the axis to reach velocity when performing a velocity move or move with final velocity
20static void HelperAtVelocityWait(MotionController *controller, Axis *axis, const int timeout)
21{
22 // The number of samples to wait before checking if the axis is at velocity
23 const int WAIT_SAMPLES = 100;
24
25 int samplesWaited = 0;
26 while (axis->StatusBitGet(RSIEventType::RSIEventTypeMOTION_AT_VELOCITY) == 0)
27 {
28 controller->SampleWait(WAIT_SAMPLES);
29 samplesWaited += WAIT_SAMPLES;
30 if (samplesWaited > timeout)
31 {
32 throw std::runtime_error("Timeout waiting for motion to reach velocity");
33 }
34 }
35}
36
37int main()
38{
39 // Print a start message to indicate that the sample app has started
40 const std::string SAMPLE_APP_NAME = "Motion: Point-to-Point";
41 SampleAppsHelper::PrintHeader(SAMPLE_APP_NAME);
42
43 /* CONSTANTS */
45 // *NOTICE* The following constants must be configured before attempting to run with hardware.
46 const int NUM_AXES = 1; // The number of axes to configure
47 const int AXIS_INDEX = 0; // The index of the axis to configure
48
49 // Motion Parameters
50 const double POSITION_0 = 0;
51 const double POSITION_1 = 0.5;
52 const double VELOCITY = 1;
53 const double ACCELERATION = 10;
54 const double DECELERATION = 10;
55 const double JERK_PERCENT = 50;
56 const double FINAL_VELOCITY = 0.5;
58
59 /* RAPIDCODE INITIALIZATION */
60 // Create the controller
62 MotionController *controller = MotionController::Create(&params);
63
64 // Set the exit code to an error value.
65 int exitCode = -1;
66 try // Ensure that the controller is deleted if an error occurs.
67 {
68 // Prepare the controller as defined in SampleAppsHelper.h depending on the configuration
70 SampleAppsHelper::SetupController(controller, NUM_AXES);
71
72 /* SAMPLE APP BODY */
73
74 /* SET CONTROLLER OBJECT COUNTS HERE*/
75 // Normally you would set the number of axes here, but for samples that is handled in the SampleAppsHelper::SetupController function
76 // controller->AxisCountSet(NUM_AXES);
77
78 // Get the axes
79 Axis *axis = controller->AxisGet(AXIS_INDEX);
81
82 // Specify a timeout for waiting for the motion to complete
83 const int32_t TIMEOUT = 10000;
84
85 // Clear faults and enable the motor
86 axis->ClearFaults();
87 axis->AmpEnableSet(true);
88
89 /* Absolute (Trapezoidal) Motion */
91 std::cout << "Absolute (Trapezoidal) Motion:" << std::endl;
92 std::cout << "Moving to position: " << POSITION_1 << std::endl;
93 axis->MoveTrapezoidal(POSITION_1, VELOCITY, ACCELERATION, DECELERATION);
94 axis->MotionDoneWait(TIMEOUT);
95 std::cout << "Motion Complete" << std::endl;
96
97 std::cout << "Moving back to position: " << POSITION_0 << std::endl;
98 axis->MoveTrapezoidal(POSITION_0, VELOCITY, ACCELERATION, DECELERATION);
99 axis->MotionDoneWait(TIMEOUT);
100 std::cout << "Motion Complete\n" << std::endl;
102
103 /* Relative Motion */
105 std::cout << "Relative Motion:" << std::endl;
106 std::cout << "Moving to position: " << POSITION_1 << std::endl;
107 axis->MoveRelative(POSITION_1 - POSITION_0, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT);
108 axis->MotionDoneWait(TIMEOUT);
109 std::cout << "Motion Complete" << std::endl;
110
111 std::cout << "Moving back to position: " << POSITION_0 << std::endl;
112 axis->MoveRelative(POSITION_0 - POSITION_1, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT);
113 axis->MotionDoneWait(TIMEOUT);
114 std::cout << "Motion Complete\n" << std::endl;
116
117 /* SCurve Motion */
119 std::cout << "SCurve Motion:" << std::endl;
120 std::cout << "Moving to position: " << POSITION_1 << std::endl;
121 axis->MoveSCurve(POSITION_1);
122 axis->MotionDoneWait(TIMEOUT);
123 std::cout << "Motion Complete" << std::endl;
124
125 std::cout << "Moving back to position: " << POSITION_0 << std::endl;
126 axis->MoveSCurve(POSITION_0);
127 axis->MotionDoneWait(TIMEOUT);
128 std::cout << "Motion Complete\n" << std::endl;
130
131 /* SCurve Motion with Final Velocity */
133 std::cout << "SCurve Motion with Final Velocity:" << std::endl;
134 std::cout << "Moving to position: " << POSITION_1 << std::endl;
135 std::cout << "Final Velocity: " << FINAL_VELOCITY << std::endl;
136 axis->MoveSCurve(POSITION_1, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT, FINAL_VELOCITY);
137 HelperAtVelocityWait(controller, axis, TIMEOUT);
138 std::cout << "Motion Complete" << std::endl;
139
140 std::cout << "Moving back to position: " << POSITION_0 << std::endl;
141 std::cout << "Final Velocity: " << 0 << std::endl;
142 axis->MoveSCurve(POSITION_0, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT, 0);
143 axis->MotionDoneWait(TIMEOUT);
144 std::cout << "Motion Complete\n" << std::endl;
146
147 /* Velocity Move */
149 std::cout << "Velocity Move:" << std::endl;
150 std::cout << "Accelerating to velocity: " << VELOCITY << std::endl;
151 axis->MoveVelocity(VELOCITY, ACCELERATION);
152 HelperAtVelocityWait(controller, axis, TIMEOUT);
153 std::cout << "Motion Complete" << std::endl;
154
155 std::cout << "Decelerating to velocity: " << 0 << std::endl;
156 axis->MoveVelocity(0, DECELERATION);
157 HelperAtVelocityWait(controller, axis, TIMEOUT);
158 std::cout << "Motion Complete" << std::endl;
160
161 // Return to the original position
162 axis->MoveTrapezoidal(POSITION_0, VELOCITY, ACCELERATION, DECELERATION);
163 axis->MotionDoneWait(TIMEOUT);
164
165 // Disable the motor
166 axis->AmpEnableSet(false);
167
168 exitCode = 0; // Set the exit code to success.
169 }
170 catch (const std::exception &ex)
171 {
172 std::cerr << ex.what() << std::endl;
173 exitCode = -1;
174 }
175 // Clean up the controller and any other objects as needed
176 SampleAppsHelper::Cleanup(controller);
177
178 // Delete the controller as the program exits to ensure memory is deallocated in the correct order
179 controller->Delete();
180
181 // Print a message to indicate the sample app has finished and if it was successful or not
182 SampleAppsHelper::PrintFooter(SAMPLE_APP_NAME, exitCode);
183
184 return exitCode;
185}
Definition rsi.h:5870
Definition rsi.h:800
int32_t MotionDoneWait()
Definition rsi.h:866
