PathMotion.cs
Attention
See the following Concept pages for a detailed explanation of this sample: Path Motion.
using NUnit.Framework;
using System;
using System.Linq;
using System.Threading;
#endif
[TestFixture]
[Category("Software")]
public class PathMotion : SampleAppTestBase
[SetUp]
public void Setup()
jointsMultiAxis?.AxisRemoveAll();
[TearDown]
public void Teardown()
robot?.EStop();
robot?.MotionDoneWait();
robot?.ClearFaults();
robot = null;
jointsMultiAxis?.Abort();
Thread.Sleep(50);
jointsMultiAxis?.ClearFaults();
private void VerifyModel(KinematicModel model, LinearUnits expectedUnits, string expectedName)
var actualUnits = model.UnitsGet();
Assert.That(actualUnits, Is.EqualTo(expectedUnits), $"Expected model units to be '{expectedUnits}' but was '{actualUnits}' instead!");
var actualName = model.NameGet();
Assert.That(actualName, Is.EqualTo(expectedName), $"Expected model name to be '{expectedName}' but was '{actualName}' instead!");
[Test]
public void GantryPrimeAxis()
prime_axis = z_axis;
// We assume the axes have been confgured and homed properly prior this this program.
const string primeLabel = "Y-Prime";
// Set the expected labels for each axis.
x_axis.UserLabelSet(xLabel);
y_axis.UserLabelSet(yLabel);
prime_axis.UserLabelSet(primeLabel);
// The joint index of each axis is the index within the MultiAxis object.
// "X-Axis" has joint index 0
// "Y-Axis" has joint index 1
// "Y-Prime" has joint index 2
Axis[] axes = new Axis[] { x_axis, y_axis, prime_axis };
const LinearUnits units = LinearUnits.Millimeters;
const string modelName = "RSI_XY_Yp";
LinearModelBuilder builder = new LinearModelBuilder(modelName);
builder.UnitsSet(units);
builder.JointAdd(new LinearJointMapping(2, CartesianAxis.Y) { ExpectedLabel = primeLabel, Scaling = scaling, Offset = offset });
// Create a Robot object where the y and y prime will be geared 1:1
const int motionFrameBufferSize = 50; // This is the minimum valid motion frame buffer size.
robot = Robot.RobotCreate(controller, jointsMultiAxis, builder, motionFrameBufferSize);
VerifyModel(robot.ModelGet(), units, modelName);
public void SimplePathMotion()
z_axis.UserLabelSet(zLabel);
a_axis.UserLabelSet(aLabel);
b_axis.UserLabelSet(bLabel);
c_axis.UserLabelSet(cLabel);
// "Z-Axis" has joint index 2
// "A-Axis" has joint index 3
// "B-Axis" has joint index 4
// "C-Axis" has joint index 5
Axis[] axes = new Axis[] { x_axis, y_axis, z_axis, a_axis, b_axis, c_axis };
const LinearUnits units = LinearUnits.Meters;
const string modelName = "RSI_XYZABC_Meters";
builder.JointAdd(new LinearJointMapping(3, CartesianAxis.Roll) { ExpectedLabel = aLabel, Scaling = scaling, Offset = offset });
builder.JointAdd(new LinearJointMapping(4, CartesianAxis.Pitch) { ExpectedLabel = bLabel, Scaling = scaling, Offset = offset });
builder.JointAdd(new LinearJointMapping(5, CartesianAxis.Yaw) { ExpectedLabel = cLabel, Scaling = scaling, Offset = offset });
// Create a Robot object with a multi axis containing all joints and the kinematic type
robot = Robot.RobotCreate(controller, jointsMultiAxis, builder, MotionController.AxisFrameBufferSizeDefault);
robot.PathAccelerationSet(1000); // UserUnits per sec sqd
robot.PathVelocitySet(50); // UserUnits per sec
robot.PathLine(new Pose(1, 1, 0));
robot.PathArc(new Pose(0, 2, 0), new Vector3d(0, 1, 0), RotationDirection.Clockwise);
jointsMultiAxis.AmpEnableSet(true);
robot.Run(); // Starts the motion. Calling with the false arguement for non blocking behavior
bool isRunning = robot.IsRunning();
[Test]
public void ChangingUnits()
const string modelName = "RSI_XYZABC_Millimeters";
//NOTE: to use the above kinematic model you must have a gantry (linear 1:1 kinematics) and each linear axis must have its user units scaled to millimeters
robot.PathAccelerationSet(10); //Sets the PATH acceleration to 10 Millimeters per second sqd
robot.PathVelocitySet(10); //Sets the PATH velocity to 10 Millimeters per second
Console.WriteLine(robot.PathUnitsGet());//This will print the int value for the enum for Millimeters
robot.PathUnitsSet(LinearUnits.Centimeters);
robot.PathAccelerationSet(10); //Sets the PATH acceleration to 10 Centimeters per second sqd
robot.PathVelocitySet(10); //Sets the PATH velocity to 10 Centimeters per second
Console.WriteLine(robot.PathLinearScalingGet());//Will print the scale factor to convert CM to MM
//NOTE: you can also set this directly. Doing so will result in PathUnitsGet() returning NONE
public void PathPoint()
const ulong frameCount = 500;
ulong totalFrames = frameCount;
ulong startFrame = 0;
while (totalFrames == frameCount)
RapidVectorRobotPosition positions = robot.PathPlannedPositionsGet(startFrame, frameCount);
totalFrames = positions.Size();
foreach (RobotPosition position in positions.ToArray())
Pose pose = position.Pose;
Vector3d spatial = pose.Position;
double xCoord = spatial.X, yCoord = spatial.Y, zCoord = spatial.Z;
Quaternion orientation = pose.Orientation;
//Add code here to create the rendering out of the positions you have collected.
//Use your prefered 3d library.
//Example:
//vector3 = new Vector3D(xPosition, yPosition, zPosition);
//linePositions.Add(Vector3DToVector3(vector3));
startFrame += totalFrames;
Definition rsi.h:5789
void UnitsSet(LinearUnits units)
Vector3d Position
The position component of the Pose.
Quaternion Orientation
The orientation component of the Pose.
Quaternion for representing rotations.
uint64_t MotionDoneWait()=0
RapidVector< RobotPosition > PathPlannedPositionsGet(uint64_t startFrame, uint64_t frameCount)=0
Get Positions (see RobotPosition) representing the planned motion in cartesian space that will happen...
void PathVelocitySet(double unitsPerSecond)=0
Sets the target linear cartesian velocity for each move (UserUnits/second).
bool IsRunning()=0
Returns whether or not the robot is in motion (from executor or other source). Can be used to determi...
double PathLinearScalingGet() const =0
Gets scaling between input to path motion and output of path motion to the kinematic model.
void PathAccelerationSet(double unitsPerSecondSquared)=0
Sets the target acceleration for the machine (UserUnits/second^2). Should be set appropriately based ...
LinearUnits PathUnitsGet() const =0
Gets the units of path motion.
void PathArc(const Pose &target, double radius, RotationDirection direction)=0
Appends an arc on to the current on the PathPlaneGet() plane XY by default.
void PathUnitsSet(LinearUnits units)=0
Defines the units Cartesian Path Motion is in.
void PathLine(const Pose &target)=0
void EStop()=0
void PathProgrammingModeSet(PathMode mode)=0
Sets the programming mode (Relative/Absolute).
void Run()=0
Run the loaded path lines/arcs. The behavior is non-blocking. Use Robot.MotionDoneWait() to block.
void ClearFaults()=0
Delete a Robot.
A representation of the robot containing the Pose and the positions of the free axes.
RSI::RapidCode::Cartesian::Pose Pose
The Robot's Pose.
Vector3d is used for three-dimensional points and vectors.
Definition rsi.h:854
Definition rsi.h:800
void AxisRemoveAll()
PathMode
Motion types. For G-code use and Cartesian path motion.
CartesianAxis
RotationDirection
Rotational directions about an axis.
LinearUnits
The Cartesian namespace.
