CreationParameters for MotionController::Create. More...
Functions | |
CreationParameters () | |
Instantiate with default values and all memory zeroed out. | |
Attributes | |
char | RmpPath [PathLengthMaximum] |
Location of the RMP firmware executable, license, and associated binaries and resources. | |
char | NicPrimary [PathLengthMaximum] |
Primary EtherCAT Network Interface (NIC) name. | |
char | NicSecondary [PathLengthMaximum] |
Secondary EtherCAT Network Interface (NIC) name. Reserved for future use. | |
char | NodeName [PathLengthMaximum] |
[Windows/INtime] Indicate the INtime node on which the RMP and RMPNetwork processes run. | |
int32_t | CpuAffinity |
[Linux] Indicate the CPU core on which the RMP and RMPNetwork processes run. | |
int32_t | RmpThreadPriorityMax |
[Linux] The maximum thread priority. All threads of the RMP and RMPNetwork will be based off of this. The maximum thread priority. 1) Must be in range RMPThreadPriorityMinimum <= RmpThreadPriorityMax <= RMPThreadPriorityMaximum OR 2) rmpThreadPriorityMax == RMPThreadPriorityNoRealTime | |
Static Attributes | |
static constexpr uint32_t | PathLengthMaximum = 256 |
MotionController::CreationParameters Maximum string buffer length. | |
static constexpr int32_t | CpuAffinityDefault = -1 |
The default value for CpuAffinity specifying no particular CPU core to run on. | |
static constexpr int32_t | RmpThreadPriorityMaximumDefault = 45 |
The default value for RmpThreadPriorityMax. | |
static constexpr int32_t | RmpThreadPriorityRange = 8 |
The priority range required for RMP and RMPNetwork threads. Minimum thread priority is this +1. | |
static constexpr int32_t | RmpThreadPriorityMinimum = RmpThreadPriorityRange + 1 |
The minimum thread priority for the real-time system. | |
static constexpr int32_t | RmpThreadPriorityMaximum = 99 |
The maximum thread priority for the real-time system. | |
static constexpr int32_t | RmpThreadPriorityNoRealTime = 0 |
The thread priority where real time properties (scheduler and relative priorities) are not set. | |
