IO: Input & Output
Learn how to work with Input/Output operations in C#.
In this page:
📜 IO: General Purpose
Learn how to access General Purpose IO 📖 on EtherCAT network nodes. Shows how to read and write digital and analog inputs/outputs using NetworkNode methods.
// get node
Helpers.CheckErrors(node);
// digital io
bool dIn = node.DigitalInGet(digitalInNumber: 0);
bool dOut = node.DigitalOutGet(digitalOutNumber: 0);
node.DigitalOutSet(digitalOutNumber: 0, state: dOut);
// analog io
int aIn = node.AnalogInGet(analogChannel: 0);
int aOut = node.AnalogOutGet(analogChannel: 0);
node.AnalogOutSet(analogChannel: 0, analogValue: aOut);
Source: io-general-purpose.cs
📜 IO: Dedicated
Learn how to access Dedicated IO 📖 on an axis. Shows how to read hardware limits, home switch, amp fault, and amp enable signals using both generic and specific methods.
// retrieve dedicated inputs with generic and specific function.
axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInLIMIT_HW_NEG),
axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInLIMIT_HW_POS),
axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInHOME),
axis.HomeSwitchGet());
axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInAMP_FAULT),
axis.AmpFaultGet());
axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInAMP_ACTIVE),
axis.AmpEnableGet());
Source: io-dedicated.cs
📜 IO: Network PDOs and SDOs
Learn how to read network inputs and outputs PDO vs. SDO 📖 . Shows how to enumerate through all network inputs/outputs and read their properties including size, offset, name, and value.
// get Input values
int inputCount = controller.NetworkInputCountGet(); // get number of Network Inputs (PDOs)
int size = controller.NetworkInputBitSizeGet(i); // read Input BitSize
int offset = controller.NetworkInputBitOffsetGet(i); // read Input BitOffset
string name = controller.NetworkInputNameGet(i); // read Input Name
UInt64 value = controller.NetworkInputValueGet(i); // read Input Value
// get Output values
int outputCount = controller.NetworkOutputCountGet(); // get number of Network Outputs (SDOs)
int size = controller.NetworkOutputBitSizeGet(i); // read Output BitSize
int offset = controller.NetworkOutputBitOffsetGet(i); // read Output BitOffset
string name = controller.NetworkOutputNameGet(i); // read Output Name
UInt64 value = controller.NetworkOutputSentValueGet(i); // read Output Value
Source: io-network-pdo-sdo.cs
📜 IO: IOPoint Objects
Learn how to use IOPoint 📖 objects to read and write network data. Shows how to create IOPoint objects for digital outputs and use them to control IO.
const int NODE_INDEX = 0; // the EtherCAT Node we will be communicating with
const int OUTPUT_INDEX = 0; // the PDO Index in that Node
// create IOPoint for digital output - automatically gets memory index of specified node and output index
// set the output to false
output0.Set(false);
Console.WriteLine($"Output {OUTPUT_INDEX} set to: false");
// wait one sample for the change to take effect
controller.SampleWait(1);
// read back the value
bool outputValue = output0.Get();
Console.WriteLine($"Output {OUTPUT_INDEX} value: {outputValue}");
// set the output to true
output0.Set(true);
Console.WriteLine($"Output {OUTPUT_INDEX} set to: true");
Source: io-iopoint.cs
📜 IO: IOPoint User Buffer
Learn how to create simulated IOPoint 📖 objects using user buffer memory. Shows how to create IOPoint objects from base memory addresses and test their functionality without actual hardware.
const int INPUT_INDEX = 0;
const int OUTPUT_INDEX = 1; // the PDO Index in the user buffer
// get user buffer address for simulated IO point storage
UInt64 userBufferAddress = controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSER_BUFFER, 0);
// create simulated IOPoints based on memory address and index
IOPoint input0 = IOPoint.CreateDigitalInput(controller, userBufferAddress, INPUT_INDEX);
IOPoint output0 = IOPoint.CreateDigitalOutput(controller, userBufferAddress, OUTPUT_INDEX);
// get & set an output
bool outVal = output0.Get();
output0.Set(outVal);
Console.WriteLine($"Output 0 value: {outVal}");
// test input operations by directly writing to memory
bool inVal = input0.Get();
Console.WriteLine($"Input 0 memory set to 1, value: {inVal}");
controller.MemorySet(input0.AddressGet(), 0);
Console.WriteLine($"Input 0 memory set to 0, value: {inVal}");
Source: io-iopoint-user-buffer.cs
📜 IO: Sync Outputs
Learn how to set up Sync Outputs for Streaming Motion Sync Outputs 📖 . Shows how to configure outputs to trigger at specific motion element IDs during streaming motion.
const int EMPTY_CT = 2; // number of points that remains in buffer before e-stop
const int OUTPUT_INDEX = 0; // digital output index that will be controlled
const int NODE_INDEX = 0; // the EtherCAT Node index
double[] positions = [1.0, 2.0, 3.0, 4.0]; // streaming motion positions
double[] times = [0.5, 0.8, 1, 0.5]; // streaming motion times
int outputEnableID = 2; // motion element ID at which to set output HIGH
int outputDisableID = 3; // motion element ID at which to set output LOW
output0.Set(false); // set output low initially
// enable streaming/sync outputs
// configure sync outputs - turn output HIGH at motion element 2, LOW at motion element 3
axis.StreamingOutputAdd(output0, true, outputEnableID); // turn output HIGH at element ID 2
axis.StreamingOutputAdd(output0, false, outputDisableID); // turn output LOW at element ID 3
Console.WriteLine($"Starting streaming motion with {TOTAL_POINTS} points");
Console.WriteLine($"Output will go HIGH at element ID {outputEnableID}");
Console.WriteLine($"Output will go LOW at element ID {outputDisableID}");
// start streaming motion
axis.MovePT(RSIMotionType.RSIMotionTypePT, positions, times, TOTAL_POINTS, EMPTY_CT, false, true);
// monitor motion and output state
while (!axis.MotionDoneGet())
int currentElement = axis.MotionElementIdExecutingGet();
bool outputState = output0.Get();
Console.WriteLine($"Motion Element: {currentElement}, Output State: {outputState}");
Thread.Sleep(50); // small delay to avoid overwhelming console
Source: io-sync-outputs.cs
