Learn how to work with Input/Output operations in C#.
- Warning
In this page:
📜 IO: General Purpose
Learn how to access General Purpose IO 📖 on EtherCAT network nodes. Shows how to read and write digital and analog inputs/outputs using NetworkNode methods.
bool dIn = node.DigitalInGet(digitalInNumber: 0);
bool dOut = node.DigitalOutGet(digitalOutNumber: 0);
node.DigitalOutSet(digitalOutNumber: 0, state: dOut);
int aIn = node.AnalogInGet(analogChannel: 0);
int aOut = node.AnalogOutGet(analogChannel: 0);
node.AnalogOutSet(analogChannel: 0, analogValue: aOut);
Source: io-general-purpose.cs
📜 IO: Dedicated
Learn how to access Dedicated IO 📖 on an axis. Shows how to read hardware limits, home switch, amp fault, and amp enable signals using both generic and specific methods.
Source: io-dedicated.cs
📜 IO: Network PDOs and SDOs
Learn how to read network inputs and outputs PDO vs. SDO 📖 . Shows how to enumerate through all network inputs/outputs and read their properties including size, offset, name, and value.
int inputCount = controller.NetworkInputCountGet();
int size = controller.NetworkInputBitSizeGet(i);
int offset = controller.NetworkInputBitOffsetGet(i);
string name = controller.NetworkInputNameGet(i);
UInt64 value = controller.NetworkInputValueGet(i);
int outputCount = controller.NetworkOutputCountGet();
int size = controller.NetworkOutputBitSizeGet(i);
int offset = controller.NetworkOutputBitOffsetGet(i);
string name = controller.NetworkOutputNameGet(i);
UInt64 value = controller.NetworkOutputSentValueGet(i);
Source: io-network-pdo-sdo.cs
📜 IO: IOPoint Objects
Learn how to use IOPoint 📖 objects to read and write network data. Shows how to create IOPoint objects for digital outputs and use them to control IO.
const int NODE_INDEX = 0;
const int OUTPUT_INDEX = 0;
Console.WriteLine($"Output {OUTPUT_INDEX} set to: false");
controller.SampleWait(1);
bool outputValue = output0.
Get();
Console.WriteLine($"Output {OUTPUT_INDEX} value: {outputValue}");
Console.WriteLine($"Output {OUTPUT_INDEX} set to: true");
Get();
Source: io-iopoint.cs
📜 IO: IOPoint User Buffer
Learn how to create simulated IOPoint 📖 objects using user buffer memory. Shows how to create IOPoint objects from base memory addresses and test their functionality without actual hardware.
const int INPUT_INDEX = 0;
const int OUTPUT_INDEX = 1;
bool outVal = output0.
Get();
Console.WriteLine($"Output 0 value: {outVal}");
bool inVal = input0.
Get();
Console.WriteLine($"Input 0 memory set to 1, value: {inVal}");
Console.WriteLine($"Input 0 memory set to 0, value: {inVal}");
Source: io-iopoint-user-buffer.cs
📜 IO: Sync Outputs
Learn how to set up Sync Outputs for Streaming Motion Sync Outputs 📖 . Shows how to configure outputs to trigger at specific motion element IDs during streaming motion.
const int TOTAL_POINTS = 4;
const int EMPTY_CT = -1;
double[] positions = [1.0, 2.0, 3.0, 4.0];
double[] times = [0.5, 0.1, 0.2, 0.4];
int outputEnableID = 2;
int outputDisableID = 3;
Console.WriteLine($"Starting streaming motion with {TOTAL_POINTS} points");
Console.WriteLine($"Output will go HIGH at element ID {outputEnableID}");
Console.WriteLine($"Output will go LOW at element ID {outputDisableID}");
axis.
MovePT(
RSIMotionType.RSIMotionTypePT, positions, times, TOTAL_POINTS, EMPTY_CT,
false,
true);
bool outputState = output0.
Get();
Console.WriteLine($"Motion Element: {currentElement}, Output State: {outputState}");
Thread.Sleep(50);
Source: io-sync-outputs.cs
