Motion: Sync Outputs (w/ Element ID)
Sync Output With Motion sample application.
Synchronize setting outputs with motion element ID's.
Precondition
#include <cassert>
#include <cmath>
#include "SampleApps.h"
int SyncOutputWithMotion::Run()
/* CONSTANTS */
const int AXIS_COUNT = 1; // number of axes
const int AXIS_NUMBER = 0; // axis number
const double USER_UNITS = 1048576; // encoder counts per rev (set as appropiate)
// Motion parameters
const double TIME_SLICE = 0.01; // 0.01s = 10ms
const int REVS = 2; // number of revolutions
const int RPS = 1; // revs / sec
const int TOTAL_POINTS = (int)(REVS / TIME_SLICE / RPS); // total number of points
const int EMPTY_CT = -1; // Number of points that remains in the buffer before an e-stop
USE_HARDWARE = false;
/* SAMPLE APP BODY */
// Initizalize the controller from software w/ multiple axes
if (USE_HARDWARE)
MultiAxis* multiAxis;
try {
// add an additional axis for the multiaxis supervisor
// create the multiaxis using the ID of the first free axis (0 indexed)
multiAxis = controller->MultiAxisGet(controller->MotionCountGet() - 1);
// populate the multiaxis
Axis* axis = controller->AxisGet(AXIS_NUMBER);
axis->EStopAbort();
axis->ClearFaults();
axis->PositionSet(0);
multiAxis->AxisAdd(axis);
// populate the positions and times
std::vector<double> positions, times;
for (int i = 0; i < TOTAL_POINTS; i += AXIS_COUNT)
positions.push_back(i * TIME_SLICE * RPS);
times.push_back(TIME_SLICE);
// prepare the controller (and drive)
multiAxis->Abort();
multiAxis->ClearFaults();
assert(multiAxis->StateGet() == RSIState::RSIStateIDLE);
multiAxis->AmpEnableSet(true);
// set up the inputs
// ensure the digital out is set low
output0->Set(0);
// The motion element ID at which to set the output
int outPutEnableID = TOTAL_POINTS / 2;
// enable streaming output
multiAxis->StreamingOutputsEnableSet(true);
// Enable the streaming output (The following are functionally equivalent)
//multiAxis->StreamingOutputAdd(output0->MaskGet(), 0, output0->AddressGet(), outPutEnableID);
multiAxis->StreamingOutputAdd(output0, true, outPutEnableID);
// Disable the output (The following are functionally equivalent)
//multiAxis->StreamingOutputAdd(0, output0->MaskGet(), output0->AddressGet(), outPutEnableID);
//multiAxis->StreamingOutputAdd(output0, false, outPutEnableID);
multiAxis->MovePT(RSIMotionType::RSIMotionTypePT, &positions[0], &times[0], TOTAL_POINTS, EMPTY_CT, false, true);
printf("Motion started. Waiting to complete.\n");
multiAxis->MotionDoneWait();
printf("Motion Complete. The outputs should have been set\n");
multiAxis->StreamingOutputsClear(); // cleanup for next run
multiAxis->EStopAbort();
catch (RsiError const& err) {
printf("\n%s\n", err.text);
return -1;
return 0;
void Set(bool state)
Definition rsi.h:12981
Axis * AxisGet(int32_t index)
Get the Axis class used in this MultiAxis class.
void AxisAdd(Axis *axis)
Definition rsi.h:12226
RSIState StateGet()
void StreamingOutputsClear()
void EStopAbort()
E-Stop, then abort an axis.
Definition rsi.h:111
@ RSIMotionTypePT
Definition rsienums.h:1180
@ RSIActionNONE
Definition rsienums.h:1257
@ RSIStateIDLE
Idle, ready for anything.
Definition rsienums.h:1016
