void MotionHoldTypeSet | ( | RSIMotionHoldType | type | ) |
type | Use RSIMotionAttrHoldType. |
If you need to hold execution based on a particular bit turning ON or OFF, use RSIMotionAttrHoldTypeUSER_ADDRESS. With RSIMotionAttrHoldTypeUSER_ADDRESS, the logic in the MotionController firmware goes something like this:
If using RSIMotionAttrHoldTypeUSER_ADDRESS or GATE, be sure to set RSIMotionAttrMaskHOLD before starting motion.
If using RSIMotionAttrHoldTypeAXIS_POSITION_COMMAND be sure to set RSIMotionAttrMaskHOLD or LESS before starting motion.
