◆ UserLimitOutputSet() [3/3]
void UserLimitOutputSet ( int32_t number,
uint32_t andMask,
uint32_t orMask,
uint64_t outputPtr,
bool enabled )
UserLimitOutputSet configures a User Limit Output block.
numberthe index of the User Limit (must be less than UserLimitCountMax).
andMask32-bit AND mask.
orMask32-bit OR mask.
*outputPtrAny controller address.
enabled1 = enabled, 0 = disabled.
IO: User Limits
// configure user limits
Helpers.CheckErrors(input0);
Helpers.CheckErrors(output0);
output0.Set(false);
number: 0,
conditionNumber: 0,
number: 0,
actionAxis: 0,
duration: 0);
number: 0,
enabled: true);
if (output0.Get())
if (!output0.Get())
output0.Set(false);
void Set(bool state)
bool Get()
Definition rsi.h:12981
RSIEventType
Event Types or Status Bits.
Definition rsienums.h:1102
RSIUserLimitLogic
Definition rsienums.h:771
Definition rsienums.h:1256
Trigger types for UserLimits.
Definition rsienums.h:758
UserLimitConditionSet, UserLimitConfigSet
To set a bit, use andMask = 0xFFFFFFFF and orMask = (bit(s) to set)
To clear a bit, use andMask = ~(bit(s) to clear) and orMask = 0
An Overload of this function accepts valueSet in place of andMask & orMask. Use this overload to set a specific value rather than using Masks.
