11.0.3
PositionToleranceCoarseSet()
void PositionToleranceCoarseSet
double
tolerance
PositionToleranceCoarseSet sets the Coarse Position Tolerance for
settling.
tolerance
In units.
AxisSettling
// get
double
posTolFine = axis.
PositionToleranceFineGet
double
posTolCoarse = axis.
PositionToleranceCoarseGet
double
velTol = axis.
VelocityToleranceGet
double
setTime = axis.
SettlingTimeGet
// set
axis.
PositionToleranceFineSet
(posTolFine);
axis.
(posTolCoarse);
axis.
VelocityToleranceSet
(velTol);
// set velocity tolerance.
axis.
SettlingTimeSet
(setTime);
Also known as Near Target distance, used to generate NEAR_TARGET interrupt
_helpers.cs
axis-config-phantom-axis.cs
axis-config-settling.cs
axis-configuration.cpp
config.h
, and
phantom-axis.cpp
1.15.0
