◆ ConfigurePhantomAxis()
static void ConfigurePhantomAxis ( MotionController controller,
int axisIndex )
static
controlleryour MotionController reference to configure.
axisIndexIndex of the phantom axis to configure.
Code Snippet
public static void ConfigurePhantomAxis(MotionController controller, int axisIndex)
Axis phantomAxis = controller.AxisGet(axisIndex);
phantomAxis.ErrorLimitActionSet(RSIAction.RSIActionNONE);
phantomAxis.HardwareNegLimitActionSet(RSIAction.RSIActionNONE);
phantomAxis.HardwarePosLimitActionSet(RSIAction.RSIActionNONE);
phantomAxis.HomeActionSet(RSIAction.RSIActionNONE);
phantomAxis.SoftwareNegLimitActionSet(RSIAction.RSIActionNONE);
phantomAxis.SoftwarePosLimitActionSet(RSIAction.RSIActionNONE);
// set position tolerances to max value for immediate MotionDone
phantomAxis.PositionToleranceCoarseSet(POSITION_TOLERANCE_MAX);
phantomAxis.PositionToleranceFineSet(POSITION_TOLERANCE_MAX);
// set the motor type to phantom
phantomAxis.MotorTypeSet(RSIMotorType.RSIMotorTypePHANTOM);
_setup.cs.
Definition at line 160 of file _helpers.cs.
