GearingCamming.cs
40using NUnit.Framework;
41using RSI.RapidCode.dotNET; // Import our RapidCode Library.
42
43#if DOXYGEN // RSI internal documentation use only
44using RSI.RapidCode;
45#endif
46
48[TestFixture]
49[Category("Software")]
50class GearingCamming : SampleAppTestBase
51 {
52 [Test, Timeout(Constants.MAX_TEST_TIME)]
53 public void Camming()
54 {
56 //Create RapidCode Objects
57 Axis moving_axis = controller.AxisGet(Constants.MAIN_AXIS_NUMBER);
58 HelperFunctions.CheckErrors(moving_axis);
59 Axis follower_axis = controller.AxisGet(Constants.DRIVEN_AXIS_NUMBER);
60 HelperFunctions.CheckErrors(follower_axis);
61
62 // Constants
63 const double MAIN_VELOCITY = 50; // Specify your Moving Axis's velocity. - units: Units/Sec (it will do 1 counts / (1/104857) of a revolution every 1 second.)
64 const double MAIN_ACCELERATION = 20; // Specify your Moving Axis's acceleration. - units: Units/Sec^2
65
66 // Commanded Positions
67 double[] movingAxisDistances = { 5, 10, 8 }; // This is the RELATIVE Moving Axis distance, every n revolutions it changes its Driven position. (This is the x-axis)
68 double[] followerAxisPositions = { 10, 20, 10 }; // This is the final ABSOLUTE Driven position, for every 5 revolutions one of this positions gets applied. (This is the y-axis)
69
70 // Command motion on the Driven before the Moving Axis starts
71 follower_axis.MoveCamLinear(moving_axis.NumberGet(),
72 RSIAxisMasterType.RSIAxisMasterTypeAXIS_COMMAND_POSITION, // Use COMMAND for phantoms and ACTUAL for real axis.
73 movingAxisDistances,
74 followerAxisPositions,
75 movingAxisDistances.Length);
76
77 moving_axis.MoveVelocity(MAIN_VELOCITY, MAIN_ACCELERATION); // Command a constant velocity on the master axis, Driven will follow.
78 follower_axis.MotionDoneWait(); // Wait for the cam motion to complet
79 moving_axis.Stop(); // Stop the Moving Axis
81
83 Assert.That(follower_axis.CommandPositionGet(), Is.EqualTo(followerAxisPositions[followerAxisPositions.Length - 1]));
84 }
85 [Test, Timeout(Constants.MAX_TEST_TIME)]
86 public void Gearing()
87 {
89 //Create RapidCode Objects
90 Axis moving_axis = controller.AxisGet(Constants.MAIN_AXIS_NUMBER);
91 HelperFunctions.CheckErrors(moving_axis);
92 Axis follower_axis = controller.AxisGet(Constants.DRIVEN_AXIS_NUMBER);
93 HelperFunctions.CheckErrors(follower_axis);
94
95 int numerator = 2; // Specify the numerator of the gearing ratio.
96 int denominator = 1; // Specify the denominator of the gearing ratio.
97
98 // Configure the 'follower' axis to be a follow to the 'moving' axis at a ratio of 2:1, that is,
99 // for every rotation of the Moving Axis axis, the Driven axis will rotate twice.
100 follower_axis.GearingEnable(moving_axis,
101 RSIAxisMasterType.RSIAxisMasterTypeAXIS_COMMAND_POSITION, // If NOT using a Phantom Axis, switch to RSIAxisMasterTypeAXIS_ACTUAL_POSITION
102 numerator,
103 denominator);
104
105 // Perform a S-curve motion on the Moving Axis axis.
106 moving_axis.MoveSCurve(Constants.POSITION,
107 Constants.VELOCITY,
108 Constants.ACCELERATION,
109 Constants.DECELERATION,
110 Constants.JERK_PERCENT);
111
112 moving_axis.MotionDoneWait(); // Wait for motion to finish.
114
116 Assert.That(moving_axis.CommandPositionGet(), Is.EqualTo(Constants.POSITION), "The command position should be equal to POSITION");
117 Assert.That(follower_axis.CommandPositionGet(), Is.EqualTo(Constants.POSITION * (numerator / denominator)), "The command position should be equal to twice POSITION");
118 }
119 }
const double POSITION
@[BasicConstants]
double CommandPositionGet()
void MoveCamLinear(int32_t masterAxisNumber, RSIAxisMasterType masterFeedbackSource, const double *const masterDistances, const double *const slavePositions, int32_t pointCount)
void GearingEnable(int32_t masterAxisNumber, RSIAxisMasterType masterFeedbackSource, int32_t numerator, int32_t denominator)
Definition rsi.h:5870
int32_t MotionDoneWait()
int32_t NumberGet()
Get the axis number.
RSIAxisMasterType
Definition rsienums.h:1218
