Motion: Streaming
Learn how to use streaming motion in C#.
In this page:
📜 Streaming Motion: PT
Learn how to use PT Streaming Motion 📖 motion with position and time arrays. PT motion is the simplest streaming motion requiring only position and time deltas. The controller calculates velocity and acceleration for each segment.
/* Demonstrates PT (Position-Time) streaming motion.
PT motion is the simplest streaming motion requiring only position and time arrays.
Console.WriteLine("📜 Axis Streaming Motion: PT");
// configure phantom axis
double[] times = [1, 0.5, 2]; // time deltas for each position (velocity and acceleration calculated by RMP)
axis.MovePT(RSIMotionType.RSIMotionTypePT, // type of PT motion (RSIMotionTypePT, RSIMotionTypeBSPLINE, RSIMotionTypeBSPLINE2)
positions, // positions to reach
times, // time deltas
true); // if this is the last MovePT call (true = final point, false = more points expected)
Definition rsi.h:5963
RSIMotionType
Definition rsienums.h:1087
📜 Streaming Motion: PVT
Learn how to use PVT Streaming Motion 📖 motion with position, velocity, and time arrays. PVT motion requires specifying positions, velocities, and time deltas. The controller calculates acceleration for each segment.
/* Demonstrates PVT (Position-Velocity-Time) streaming motion.
PVT motion requires position, velocity, and time arrays.
Console.WriteLine("📜 Axis Streaming Motion: PVT");
double[] velocities = [12.0, 10.0, 6.0]; // velocities for each position
double[] times = [0.1, 0.2, 0.1]; // time deltas (acceleration calculated by RMP)
axis.MovePVT(positions, // positions to reach
true); // if this is the last MovePVT call (true = final point, false = more points expected)
📜 Streaming Motion: PVAJT
Learn how to use PVAJT Streaming Motion 📖 motion with position, velocity, acceleration, jerk, and time arrays. PVAJT motion provides complete control over all motion parameters for each segment.
/* Demonstrates PVAJT (Position-Velocity-Acceleration-Jerk-Time) streaming motion.
PVAJT motion requires position, velocity, acceleration, jerk, and time arrays.
The controller uses all specified motion parameters for each segment.
Console.WriteLine("📜 Axis Streaming Motion: PVAJT");
double[] velocities = [10.0, 20.0, 40.0]; // velocities for each position
double[] accelerations = [4, 4, 4]; // accelerations for each move
double[] jerks = [50, 50, 50]; // jerks for each move
double[] times = [0.4, 0.2, 0.1]; // time deltas for each position
axis.MovePVAJT(positions, // positions to reach
accelerations, // accelerations for each move
jerks, // jerks for each move
true); // if this is the last MovePVAJT call (true = final point, false = more points expected)
📜 Streaming Motion: PT While Stopping
Learn how to handle stopping and resuming PT Streaming Motion 📖 motion. Demonstrates the difference between Resume() to continue appending points versus starting fresh motion.
/* Demonstrates how to handle PT streaming motion when stopping.
Shows the difference between Stop/Resume to continue appending points,
versus starting fresh motion after stopping.
Console.WriteLine("📜 Axis Streaming Motion: PT While Stopping");
axis.PositionSet(0); // start at position 0
const int points = 3; // points per streaming motion call
const int emptyCount = 2; // e-stop generated if there are this number or fewer frames loaded
double[] first = [0.1, 0.2, 0.3]; // positions for first MovePT call
double[] second = [0.4, 0.5, 0.6]; // positions for second MovePT call
double[] third = [0.7, 0.8, 0.9]; // positions for third MovePT call
double[] time1 = [0.3, 0.3, 0.3]; // time deltas for first MovePT call
double[] time2 = [0.2, 0.2, 0.2]; // time deltas for second MovePT call
double[] time3 = [0.25, 0.25, 0.25]; // time deltas for third MovePT call
axis.MovePT(RSIMotionType.RSIMotionTypePT, first, time1, points, emptyCount, false, false); // start motion and stream points
axis.MovePT(RSIMotionType.RSIMotionTypePT, second, time2, points, emptyCount, false, false); // append points
// after Stop() on streaming motion, you can:
// 1. Resume() to continue appending points to existing motion
// 2. Discard previous points and start new motion
axis.Stop(); // puts axis in STOPPED state
// axis.EStop(); // puts axis in ERROR state (must ClearFaults() before continuing)
// axis.Abort(); // puts axis in ERROR state and triggers AmpEnable(false) (must call AmpEnable(true) before continuing)
Console.WriteLine("Motion stopped.");
axis.MotionDoneWait(); // wait for axis to stop
axis.Resume(); // resume appends next points to existing motion, without Resume(), new points start fresh motion
// append or start new based on Resume() call
axis.MovePT(RSIMotionType.RSIMotionTypePT, third, time3, points, emptyCount, false, true);
void Resume()
Resume an axis.
