IOPoint
Represents one specific point: Digital Output, Digital Input, Analog Output, or Analog Input. This class provides a helper interface to any I/O, regardless of where it resides: MotionController, Axis, or NetworkNode. To create an IOPoint, use IOPoint Creation Methods. More...
Static Functions
static IOPointCreateDigitalInput (Axis *axis, RSIMotorDedicatedIn motorDedicatedInNumber)
static IOPointCreateDigitalInput (Axis *axis, RSIMotorGeneralIo motorGeneralIoNumber)
 Create a Digital Input from an Axis' general purpose inputs.
static IOPointCreateDigitalInput (NetworkNode *networkNode, int32_t bitNumber)
 Create a Digital Input from a RapidCodeNetworkNode.
static IOPointCreateDigitalInput (MotionController *controller, int32_t pdoIndex, int32_t bitNumber, RSIPDOType type)
 Create a Digital Output from a network PDO.
static IOPointCreateDigitalInput (MotionController *controller, uint64_t memoryAddress, int32_t bitNumber)
static IOPointCreateDigitalOutput (Axis *axis, RSIMotorDedicatedOut motorDedicatedOutNumber)
static IOPointCreateDigitalOutput (Axis *axis, RSIMotorGeneralIo motorGeneralIoNumber)
 Create a Digital Output from an Axis' general purpose inputs.
static IOPointCreateDigitalOutput (NetworkNode *networkNode, int32_t bitNumber)
 Create a Digital Output from a RapidCodeNetworkNode.
static IOPointCreateDigitalOutput (MotionController *controller, int32_t pdoIndex, int32_t bitNumber, RSIPDOType type)
static IOPointCreateDigitalOutput (MotionController *controller, uint64_t memoryAddress, int32_t bitNumber)
static IOPointCreateAnalogInput (NetworkNode *networkNode, int32_t analogChannel)
 Create an Analog Input from a RapidCodeNetworkNode.
static IOPointCreateAnalogOutput (NetworkNode *networkNode, int32_t analogChannel)
 Create an Analog Output from a RapidCodeNetworkNode.
Functions
uint64_t AddressGet ()
int32_t MaskGet ()
bool IsDigital ()
 Determine if an I/O point is Digital or Analog.
bool IsOutput ()
 Determine if an I/O point is an output.
bool Get ()
void Set (bool state)
double ValueGet ()
 Get the value of an Analog Input or Output.
void ValueSet (double valueDouble)
 Set the value for an Analog Output.
int32_t MpiVersionMajor ()
 Get the major MPI version.
int32_t MpiVersionMinor ()
 Get the minor MPI version.
int32_t MpiVersionRelease ()
 Get the release MPI version.
int32_t RSIVersionMajor ()
 Get the major RSI version.
int32_t RSIVersionMinor ()
 Get the minor RSI version.
int32_t RSIVersionMicro ()
 Get the micro RSI version.
int32_t RSIVersionPatch ()
 Get the patch RSI version.
int32_t NumberGet ()
int32_t ErrorLogCountGet ()
void ErrorLogClear ()
 Clear the error log.
void Trace (bool state)
void TraceMaskClear ()
 Clear the trace output mask.
void TraceFileClose ()
 Stops Logging to the file.
Description
The IOPoint objects will all be automatically deleted when the MotionController object is deleted.
InputOutput.cs, Recorder.cs, SingleAxisSyncOutputs.cpp, SyncOutputWithMotion.cpp, UserLimit.cs, and UserLimitDigitalInputAction.cpp.
Definition at line 10971 of file rsi.h.
