More...
const char *const | UserLabelGet () |
| Get the IO User defined Label.
void | UserLabelSet (const char *const userLabel) |
| Set the IO User defined Label.
bool | IOExists () |
| IOExists validates your IO object is an IO Node.
int32_t | NumberGet () |
| Get the zero-based IO number.
bool | DigitalInGet (int32_t digitalInNumber) |
| Get the state of a digital input bit.
bool | DigitalOutGet (int32_t digitalOutNumber) |
| Get the state of a Digital Output bit.
void | DigitalOutSet (int32_t digitalOutNumber, bool outValue) |
| Set the state of a digital output bit.
int32_t | AnalogInGet (int32_t analogChannel) |
| Get the value of an analog input.
int32_t | AnalogOutGet (int32_t analogChannel) |
| Get the value of an analog output.
void | AnalogOutSet (int32_t analogChannel, int32_t analogValue) |
| Set the value of an analog output.
const char *const | VersionGet () |
| Get the RSI RapidCode version.
int32_t | MpiVersionMajor () |
| Get the major MPI version.
int32_t | MpiVersionMinor () |
| Get the minor MPI version.
int32_t | MpiVersionRelease () |
| Get the release MPI version.
int32_t | RSIVersionMajor () |
| Get the major RSI version.
int32_t | RSIVersionMinor () |
| Get the minor RSI version.
int32_t | RSIVersionMicro () |
| Get the micro RSI version.
int32_t | RSIVersionPatch () |
| Get the patch RSI version.
int32_t | ErrorLogCountGet () |
| Get the number of software errors in the error log.
const RsiError *const | ErrorLogGet () |
| Get the next RsiError in the log.
void | ErrorLogClear () |
| Clear the error log.
void | ThrowExceptions (bool state) |
| Configure a class to throw exceptions.
const char *const | RsiErrorMessageGet (RSIErrorMessage msg) |
| Get the RSI-specific error message text for a specific RSIErrorMessage.
const char *const | ErrorMessageGet (RSIErrorMessage msg) |
| Get the detailed text message for an RSIErrorMessage.
bool | WarningMsgCheck (RSIErrorMessage msg) |
| Check to see if an RSIErrorMessage is a warning (true) or not (false).
void | Trace (bool state) |
| Enables/Disables trace output.
void | TraceMaskOnSet (RSITrace maskOn) |
| Turn on a particular trace output mask.
bool | TraceMaskOnGet (RSITrace maskOn) |
| Check to see if a particular trace output mask is turned on.
void | TraceMaskOffSet (RSITrace maskOff) |
| Turn off a particular trace output mask.
void | TraceMaskClear () |
| Clear the trace output mask.
void | TraceFileSet (const char *const fileName) |
| Channels Tracing messages to specified file.
void | TraceFileClose () |
| Stops Logging to the file.
void | TraceInjectMessage (RSITrace traceLevel, const char *const message) |
| Add a message to the Trace Log.
An IO node can have various combinations of digital or analog inputs and outputs. IO objects contain a RapidCodeNetworkNode.
Definition at line 11948 of file rsi.h.
