Learn how to modify motion in-flight in C#.
- Warning
In this page:
📜 Feed Rate
Learn how to use Feed Rate 📖 to adjust motion speed in-flight. Shows how to increase speed, stop, reverse motion, and resume without changing controller state.
axis.
MoveSCurve(POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT);
Console.WriteLine($"\tPosition commanded: {POSITION}");
Thread.Sleep(10);
Console.WriteLine($"\tPosition after FeedRate (1.5): {axis.CommandPositionGet()}");
Thread.Sleep(500);
Console.WriteLine($"\tPosition after FeedRate (-1): {axis.CommandPositionGet()}");
Console.WriteLine($"\tPosition after FeedRate (1): {axis.CommandPositionGet()} (expected: {POSITION})");
Source: axis-motion-modify.cs
📜 Change Motion Speed
Learn how to change the velocity parameter of a motion that is partially complete. Demonstrates issuing a new move command mid-motion to change speed on the fly.
axis.
Thread.Sleep(10);
Console.WriteLine($"\tPosition before speed change: {axis.CommandPositionGet()}");
axis.
MoveSCurve(POSITION, VELOCITY * 10, ACCELERATION, DECELERATION, JERK_PERCENT);
