using RSI.RapidCode.dotNET;
using NUnit.Framework;
[TestFixture]
[Category("Software")]
public class Motion : SampleAppTestBase
    public void AbsoluteMotion()
      axis.
MoveTrapezoidal(Constants.POSITION, Constants.VELOCITY, Constants.ACCELERATION, Constants.DECELERATION);
      Assert.That(axis.
CommandPositionGet(), Is.EqualTo(Constants.POSITION),
"The command position should be equal to POSITION");
    public void SCurveMotion()
      Assert.That(axis.
    public void FinalVelocity()
      int finalVelocity = 5;
                      Constants.VELOCITY,
                      Constants.DECELERATION,
                      Constants.JERK_PERCENT,
                      finalVelocity);
        Assert.That(axis.
CommandVelocityGet(), Is.EqualTo(finalVelocity),
"The command velocity should be equal to FINAL_VELOCITY");
        TearDown();
    public void RelativeMotion()
      axis.
MoveRelative(Constants.POSITION, Constants.VELOCITY, Constants.ACCELERATION, Constants.DECELERATION, Constants.JERK_PERCENT);
      axis.
MoveRelative(-1 * Constants.POSITION, Constants.VELOCITY, Constants.ACCELERATION, Constants.DECELERATION, Constants.JERK_PERCENT);
      Assert.That(cmdPositionAfterMove, Is.EqualTo(Constants.POSITION), "The command position should be equal to POSITION");
    [Test]
    public void MoveVelocity()
      axis.
MoveVelocity(Constants.VELOCITY, Constants.ACCELERATION);
        Assert.That(axis.
CommandVelocityGet(), Is.EqualTo(Constants.VELOCITY),
        TearDown();
double CommandPositionGet()
double CommandVelocityGet()
Get the current commanded velocity.
int32_t MotionDoneWait()
