◆ Home() [1/2]
void Home ( )
Home executes the homing routine as configured with the other homing methods. At the completion of finding the index / marker pulse, or the desired switch, the Axis will set the Home Offset, and then move to the zero position. If you don't want the Axis to move to zero after homing, use the overloaded method and set "moveToZero" false.
Axis: Homing
// get rmp controller
return;
// configure limit action
// execute homing routine
axis.Home();
// clean up
axis.ClearFaults();
axis.AmpEnableSet(false);
Definition _helpers.cs:15
Helpers class provides static methods for common tasks in RMP applications.
Definition _helpers.cs:5
Set the slow home velocity.
Set the home velocity.
void Home()
Execute the homing routine.
bool HomeStateGet()
Get the home state.
Definition rsi.h:5870
Definition rsi.h:800
Definition rsienums.h:568
Definition rsienums.h:1115
Notes:
Be sure to set Home Action to RSIActionSTOP. Also set HW Positive/Negative Limit actions to STOP if homing with limit switches.
HomeMethodSet, HomeOffsetSet, HomeVelocitySet, HomeAccelerationSet, HomeDecelerationSet, HomeActionSet
Master-based homing.
PathMotion.cpp, and axis-homing-master-based.cs.
