10.6.0
AmpFaultActionSet()
void AmpFaultActionSet
action
AmpFaultActionSet sets the action to be performed when the Amp Fault triggers.
Note:
Available Actions are
Abort()
EStop()
Stop()
, None,
EStopAbort()
, and
EStopModify()
action
Action taken on Amp Fault event. A
value.
Axis: Configuration
const
double
AMP_FAULT_DURATION_TIME = 1;
//value in seconds
// SET
axis.
AmpEnableSet
false
// Disable the amp
axis.
AmpFaultActionSet
.RSIActionABORT);
// Set the action that will occur when there is an amp fault.
axis.
AmpFaultTriggerStateSet
false
//Set the state of the amp fault.
axis.
AmpFaultDurationSet
(AMP_FAULT_DURATION_TIME);
//Set the duration required before the Amp Fault event triggers.
// GET
var isEnabled = axis.
AmpEnableGet
var faultAction = axis.
AmpFaultActionGet
var faultTriggerState = axis.
AmpFaultTriggerStateGet
var faultDuration = axis.
AmpFaultDurationGet
Go to axis screen->Limits & Actions. In image below, AmpFaultActionSet sets the action type shown in the Amp Fault box. It is currently set to ABORT.
AmpFaultActionGet()
AxisConfig.cs
AxisConfiguration.cpp
PhantomAxis.cpp
, and
SampleAppsHelper.h
1.10.0
