Learn the basic structure for building RapidCode C++ applications.
- Warning
In this page:
📜 Template: Basic Structure
Basic template structure for building RapidCode C++ applications with proper initialization, error handling, and cleanup patterns.
const int NUM_AXES = 0;
int exitCode = -1;
std::cout << "Hello World!" << std::endl;
exitCode = 0;
exitCode = -1;
controller->Delete();
Source: starter-template.cpp
