helpers.h
See ⚙️ Helpers 📜 for a detailed explanation of this sample code.
#ifndef HELPERS
#define HELPERS
// These macros are defined as part of the build process in CMake. To avoid
// build errors, we default them to empty strings if they are not defined.
#ifndef RMP_INSTALL_PATH
#define RMP_INSTALL_PATH ""
#endif
#include <iostream>
#include <string>
#include <sstream>
#include <source_location>
using namespace RSI::RapidCode; // Import our RapidCode namespace
namespace Helpers
const char* NetworkStartErrorName(RSINetworkStartError error)
switch (error)
return "RSINetworkStartErrorNETWORK_START_OK";
return "RSINetworkStartErrorNIC_PASSED";
return "RSINetworkStartErrorDEVICES_CONNECTED_POWERED";
return "RSINetworkStartErrorDISCOVERED_ZERO_NODES";
return "RSINetworkStartErrorGENERAL_DISCOVERY_FAILURE";
return "RSINetworkStartErrorNETWORK_INIT_FAILURE";
return "RSINetworkStartErrorINCORRECT_ENI_FORMAT";
return "RSINetworkStartErrorSLAVE_COMM_FAILED";
return "RSINetworkStartErrorMEMORY_CONFIG";
return "RSINetworkStartErrorETHERCAT_MASTER_STARTUP_ERROR";
return "RSINetworkStartErrorINTERNAL_RMP_ERROR";
return "RSINetworkStartErrorINTIME_OPEN_ERROR";
return "RSINetworkStartErrorFAILED_TO_READ_PRODUCT_CODE";
return "RSINetworkStartErrorFAILED_TO_READ_VENDOR_ID";
return "RSINetworkStartErrorFAILED_TO_READ_REVISION";
return "RSINetworkStartErrorFAILED_TO_READ_SERIAL_NO";
return "RSINetworkStartErrorFAILED_TO_READ_STATION_ALIAS";
return "RSINetworkStartErrorTHREAD_SCHEDULING_OR_PRIORITY";
return "RSINetworkStartErrorETHERCAT_SAFETY_NOT_LICENSED";
return "RSINetworkStartErrorETHERCAT_SAFETY_MAIN_DEVICE_NOT_DETECTED";
return "RSINetworkStartErrorUNSUPPORTED_NODE_DETECTED";
return "RSINetworkStartErrorENI_SAMPLE_RATE_MISMATCH";
return "RSINetworkStartErrorCPU_AFFINITY";
default:
return "RSINetworkStartErrorUNKNOWN";
void CheckErrors(RapidCodeObject *rsiObject, const std::source_location &location = std::source_location::current())
bool hasErrors = false;
std::string errorStrings("");
const RsiError *err = rsiObject->ErrorLogGet();
errorStrings += err->what();
errorStrings += "\n";
if (!err->isWarning)
hasErrors = true;
if (hasErrors)
std::ostringstream message;
message << "Error! In "
<< location.file_name() << '('
<< location.line() << ':'
<< location.column() << ") `"
<< location.function_name() << "`:\n"
<< errorStrings;
// Initialize the Network
if (controller->NetworkStateGet() != RSINetworkState::RSINetworkStateOPERATIONAL) // Check if network is started already.
controller->NetworkStart(); // If not. Initialize The Network. (This can also be done from RapidSetup Tool)
if (controller->NetworkStateGet() != RSINetworkState::RSINetworkStateOPERATIONAL) // Check if network is started again.
RSINetworkStartError startError = controller->LastNetworkStartErrorGet();
std::cout << "Network start error: " << NetworkStartErrorName(startError)
<< " (" << static_cast<int>(startError) << ")" << std::endl;
int messagesToRead = controller->NetworkLogMessageCountGet(); // Some kind of error starting the network, read the network log messages
// Check if the network is already shutdown
if (controller->NetworkStateGet() == RSINetworkState::RSINetworkStateUNINITIALIZED ||
controller->NetworkStateGet() == RSINetworkState::RSINetworkStateSHUTDOWN)
return;
// Shutdown the network
controller->NetworkShutdown();
if (controller->NetworkStateGet() != RSINetworkState::RSINetworkStateUNINITIALIZED &&
controller->NetworkStateGet() != RSINetworkState::RSINetworkStateSHUTDOWN) // Check if the network is shutdown.
int messagesToRead = controller->NetworkLogMessageCountGet(); // Some kind of error shutting down the network, read the network log messages
else // Else, of network is shutdown.
std::cout << "----------------------------------------------------------------------------------------------------\n";
std::cout << "Running " << sampleAppName << " Sample App\n";
std::cout << "----------------------------------------------------------------------------------------------------\n" << std::endl;
std::cout << "\n----------------------------------------------------------------------------------------------------\n";
if (exitCode == 0)
std::cout << sampleAppName << " Sample App Completed Successfully\n";
std::cout << sampleAppName << " Sample App Failed with Exit Code: " << exitCode << "\n";
} // namespace Helpers
#endif // HELPERS
int32_t ErrorLogCountGet()
Definition rsi.h:180
Definition rsi.h:111
bool isWarning
Definition rsi.h:120
Definition rsi.h:169
@ RSINetworkStateSHUTDOWN
Definition rsienums.h:628
@ RSINetworkStateOPERATIONAL
Definition rsienums.h:626
EtherCAT not yet started.
Definition rsienums.h:622
Network start errors.
Definition rsienums.h:715
@ RSINetworkStartErrorNIC_PASSED
Invalid or unusable NIC/interface selection. Verify NIC name, interface state, and permissions.
Definition rsienums.h:717
@ RSINetworkStartErrorINCORRECT_ENI_FORMAT
ENI data is invalid or unreadable. Regenerate or replace the ENI file.
Definition rsienums.h:722
@ RSINetworkStartErrorETHERCAT_SAFETY_MAIN_DEVICE_NOT_DETECTED
Safety configuration was detected but no supported Safety MainDevice was found.
Definition rsienums.h:742
@ RSINetworkStartErrorMEMORY_CONFIG
Memory/configuration allocation failed during network startup. Restart and review network logs.
Definition rsienums.h:726
@ RSINetworkStartErrorENI_SAMPLE_RATE_MISMATCH
The ENI cycle time does not match the configured SampleRate. Regenerate the ENI after changing the sa...
Definition rsienums.h:744
@ RSINetworkStartErrorSLAVE_COMM_FAILED
Startup communication with one or more EtherCAT slaves failed. Verify wiring and slave health.
Definition rsienums.h:725
@ RSINetworkStartErrorFAILED_TO_READ_STATION_ALIAS
Failed to read Station Alias from a slave device. Verify slave communication stability.
Definition rsienums.h:736
@ RSINetworkStartErrorFAILED_TO_READ_PRODUCT_CODE
Failed to read Product Code from a slave device. Verify slave communication stability.
Definition rsienums.h:732
@ RSINetworkStartErrorINTIME_OPEN_ERROR
INtime open/init operation failed. Verify INtime runtime status and platform setup.
Definition rsienums.h:729
@ RSINetworkStartErrorDISCOVERED_ZERO_NODES
Discovery completed with zero nodes found. Verify topology and that slaves are powered.
Definition rsienums.h:719
@ RSINetworkStartErrorDEVICES_CONNECTED_POWERED
EtherCAT devices could not be reached. Verify cabling, power, and link status.
Definition rsienums.h:718
@ RSINetworkStartErrorCPU_AFFINITY
Linux CPU affinity is not set to a single core.
Definition rsienums.h:745
@ RSINetworkStartErrorNETWORK_INIT_FAILURE
Network startup failed after initial setup. Review network logs and configuration.
Definition rsienums.h:721
@ RSINetworkStartErrorETHERCAT_MASTER_STARTUP_ERROR
EtherCAT master failed to reach the required startup state. Check logs and network configuration.
Definition rsienums.h:727
@ RSINetworkStartErrorFAILED_TO_READ_VENDOR_ID
Failed to read Vendor ID from a slave device. Verify slave communication stability.
Definition rsienums.h:733
@ RSINetworkStartErrorFAILED_TO_READ_SERIAL_NO
Failed to read Serial Number from a slave device. Verify slave communication stability.
Definition rsienums.h:735
@ RSINetworkStartErrorNETWORK_START_OK
No startup error. Network start completed successfully.
Definition rsienums.h:716
@ RSINetworkStartErrorFAILED_TO_READ_REVISION
Failed to read Revision from a slave device. Verify slave communication stability.
Definition rsienums.h:734
@ RSINetworkStartErrorUNSUPPORTED_NODE_DETECTED
An unsupported node on the network is blocking EtherCAT startup.
Definition rsienums.h:743
@ RSINetworkStartErrorTHREAD_SCHEDULING_OR_PRIORITY
Failed to set required thread scheduling/priority. Verify RT kernel support and privileges.
Definition rsienums.h:739
@ RSINetworkStartErrorETHERCAT_SAFETY_NOT_LICENSED
Safety configuration was detected but the required safety license is not present.
Definition rsienums.h:741
@ RSINetworkStartErrorGENERAL_DISCOVERY_FAILURE
Discovery failed for an unspecified reason. Check network logs and retry discovery/start.
Definition rsienums.h:720
@ RSINetworkStartErrorINTERNAL_RMP_ERROR
Internal controller/runtime error occurred while starting the network. Restart and collect logs.
Definition rsienums.h:728
Definition helpers.h:87
[CheckErrors]
Definition helpers.h:128
[NetworkShutdown]
Definition helpers.h:205
void NetworkShutdown(MotionController *controller)
[NetworkStart]
Definition helpers.h:167
[PrintHeader]
Definition helpers.h:221
