Learn how to read axis status and check for errors.
Console.WriteLine("📜 Axis: Status");
Console.WriteLine($"Your Axis is in state: {state}");
switch (state)
Console.WriteLine($"The source of the axis error is: {axis.SourceNameGet(source)}");
default:
Console.WriteLine("Axis is in an unexpected state.");
Console.WriteLine($"Amp Fault Active: {isAmpFaultActive}");
Console.WriteLine($"Position Error Limit Active: {isPosErrLimActive}");
Console.WriteLine($"HW Negative Limit Active: {isHwNegLimActive}");
Console.WriteLine($"HW Positive Limit Active: {isHwPosLimActive}");
controller.Delete();
RSIState StateGet()
RSISource SourceGet()
RSIEventType
Event Types or Status Bits.
RSISource
