rttaskfunctions.cpp
See Real-Time Tasks 📜 for a detailed explanation of this sample code.
#include "rttaskglobals.h"
#include <cstdlib>
#include <ctime>
#include <cmath>
#include <iostream>
using namespace RSI::RapidCode;
// initialize the global data and random number generator
RSI_TASK(Initialize)
data->counter = 0;
data->sensorValue = 0;
data->startingSample = 0;
std::srand(std::time(nullptr));
// increment the counter in the global data
RSI_TASK(Increment)
data->counter += 1;
// Simulate getting sensor value with sine wave
double getSensorValue(MotionController *controller, int32_t startingSample) {
double FREQUENCY = 0.5; // Oscillations/second
double AMPLITUDE = 0.25; // Oscillation strength (user units)
double PI = 3.1415; // Approximation of pi
double secondsElapsed = ((double) controller->SampleCounterGet() - startingSample) / controller->SampleRateGet();
return AMPLITUDE * std::sin(2 * PI * FREQUENCY * secondsElapsed);
// move the axis to follow a simulated sensor value
RSI_TASK(FollowSensor)
MotionController *controller = RTMotionControllerGet();
if (data->startingSample == 0) {
data->startingSample = controller->SampleCounterGet();
data->sensorValue = getSensorValue(controller, data->startingSample);
RTAxisGet(0)->MoveTrapezoidal(data->sensorValue, 5, 10, 10);
The RealTimeTasks namespace.
Definition rttask.h:36
