rttasks-helpers.h
See Real-Time Tasks 📜 for a detailed explanation of this sample code.
#ifndef RT_TASKS_HELPERS
#define RT_TASKS_HELPERS
#include "rttask.h"
#include <iostream>
#include <memory>
using namespace RSI::RapidCode; // Import our RapidCode namespace
using namespace RSI::RapidCode::RealTimeTasks; // Import the RealTimeTasks namespace
namespace RTTaskHelper
// get the creation parameters for the task manager
#if defined(WIN32) && defined(NDEBUG)
// if we are on windows and not debug, then we need to create an intime task manager
RTTaskManagerCreationParameters GetTaskManagerCreationParameters()
std::snprintf(
parameters.RTTaskDirectory,
RMP_INSTALL_PATH // the rmp install directory
std::snprintf(
parameters.NodeName,
"NodeA"
return parameters;
#else
// otherwise, we are on linux or debug, so we can create a native task manager
std::snprintf(
// for linux real-time set this to an isolated core
// parameters.CpuCore = -1;
return parameters;
#endif // defined(WIN32) && defined(NDEBUG)
// this calls a task to initialize the global variables and get pointers to rapidcode objects
// in the rttaskfunctions library. it needs to be called before any task
// that uses rapidcode objects.
void SubmitInitializationTask(RTTaskManager &manager)
std::cout << "Running initialization task..." << std::endl;
RTTaskCreationParameters initParams("Initialize");
RTTask task = manager.TaskSubmit(initParams);
constexpr int timeoutMs = 5000;
task.ExecutionCountAbsoluteWait(1, timeoutMs); // wait for the task to execute once.
// Returns the RTTaskState as a printable string
const char* StateToString(RTTaskState state) {
switch (state) {
case RTTaskState::Dead: return "DEAD";
case RTTaskState::Running: return "RUNNING";
case RTTaskState::Waiting: return "WAITING";
case RTTaskState::Disabled: return "DISABLED";
default: return "UNKNOWN";
#endif // RT_TASKS_HELPERS
Definition rttask.h:438
RTTask TaskSubmit(const RTTaskCreationParameters &parameters)
Submit a new task to the manager using creation parameters.
Interface for managing real-time tasks firmware. See Real-Time Tasks for more information.
Definition rttask.h:562
RTTaskState
Enum representing the possible states of a real-time task.
Definition rttask.h:64
@ Dead
Task is not initialized or has been terminated.
Definition rttask.h:65
@ Waiting
Task is active but waiting for its next scheduled execution time.
Definition rttask.h:67
@ Running
Task is currently executing.
Definition rttask.h:68
@ Disabled
Task is initialized but not currently executing.
Definition rttask.h:66
The RealTimeTasks namespace.
Definition rttask.h:36
Definition rttask.h:126
int32_t Repeats
Number of times the task should execute (RepeatForever for infinite, 0 for none (one-shot)).
Definition rttask.h:170
static constexpr int32_t RepeatNone
Special value to indicate the task should not repeat.
Definition rttask.h:143
char RTTaskDirectory[DirectoryLengthMaximum]
Path to the directory containing the rttaskmanager executable.
Definition rttask.h:342
Definition rttask.h:320
PlatformType Platform
Platform on which the manager firmware will run.
Definition rttask.h:345
static constexpr int32_t DirectoryLengthMaximum
Maximum length of the directory path.
Definition rttask.h:322
char NodeName[NameLengthMaximum]
[INtime] Name of the node on which the manager will run. By default, this is set to (and verified as)...
Definition rttask.h:349
static constexpr int32_t NameLengthMaximum
Maximum length of name fields (node name, user label).
Definition rttask.h:325
