10.6.0
HomeJerkPercentSet()
[1/2]
void HomeJerkPercentSet
double
percent
HomeJerkPercentSet sets the jerk percent used for homing.
percent
(0.0 to 100.0)
Homing
Axis: Homing
axis.
HardwareNegLimitActionSet
.RSIActionSTOP);
// Neg Limit action set to STOP.
axis.
HomeMethodSet
RSIHomeMethod
.RSIHomeMethodImprovedFALLING_HOME_NEGATIVE_START_POSITIVE_MOMENTUM);
// Set the method to be used for homing.
axis.
HomeVelocitySet
(Constants.VELOCITY);
// Set the home velocity.
axis.
HomeSlowVelocitySet
(Constants.VELOCITY / 10);
// Set the slow home velocity. (used for final move, if necessary)
axis.
HomeAccelerationSet
(Constants.ACCELERATION);
// Set the acceleration used for homing.
axis.
HomeDecelerationSet
(Constants.DECELERATION);
// Set the deceleration used for homing.
axis.
HomeOffsetSet
(0.5);
// HomeOffsetSet sets the position offset from the home (zero) position.
axis.
Home
// Execute the homing routine.
if
(axis.
HomeStateGet
true
// HomeStateGet returns true if the Axis is homed.
Console.WriteLine(
"Homing successful\n"
axis.
ClearFaults
// Clear faults created by homing.
axis.
AmpEnableSet
false
// Disable the motor.
HomeJerkPercentSet(double)
will set Jerk for all stages to support legacy customers.
Home
Master-based homing diagrams.
1.10.0
