static |
controller | Pointer to the MotionController containing the axis. |
axisNumber | The number of the axis to configure as a phantom axis. |
SystemException | Thrown if an invalid axis number is provided. {
// Check if the axis number is valid
if (axisNumber < 0)
throw new SystemException("Error: " + axisNumber.ToString() + " is invalid. Axis numbers cannot be negative.");
if (axisNumber >= controller.AxisCountGet())
throw new SystemException("Error: " + axisNumber.ToString() + " is invalid. Axis numbers cannot be greater than the number of axes on the controller.");
// Configure the specified axis as a phantom axis
HelperFunctionsCS.CheckErrors(axis); // [Helper Function] Check that the axis has been initialized correctly
axis.PositionSet(0); // Set the position to 0
const double positionToleranceMax = Double.MaxValue / 10.0; // Reduce from max slightly, so XML to string serialization and deserialization works without throwing System.OverflowException
axis.PositionToleranceCoarseSet(positionToleranceMax); // Set Settling Coarse Position Tolerance to max value
axis.PositionToleranceFineSet(positionToleranceMax); // Set Settling Fine Position Tolerance to max value (so Phantom axis will get immediate MotionDone when target is reached)
Definition at line 212 of file HelperFunctionsCS.cs.
