VelocitySetByAnalogInputValue.cs
27using RSI.RapidCode.dotNET; // Import our RapidCode Library.
28using System;
29
30#if DOXYGEN // RSI internal documentation use only
31using RSI.RapidCode;
32#endif
33
35class VelocitySetByAnalogInputValue
36 {
37 static void Main(string[] args)
38 {
40 // GLOBAL VARIABLES
41 double analogMaxValue = 65536; // The analog inputs used are 16 bit wide.
42 double currentVelocity = 0; // Used to update velocity based on analog input value.
43 double analogCurrentValue = 0; // Used to store current analog input value.
44 double analogValuePrecentage = 0; // analogCurrentValue/anlogMaxValue.
45 double velocityAbsoluteSum = 0; // Absolute sum of min and max velocities.
46
47 // CONSTANTS
48 const int AXIS_NUMBER = 0; // Specify which axis/motor to control.
49 const int NODE_NUMBER = 0; // Specify which IO Terminal/Node to control. 0 for RSI AKD DemoBench
50 const int ANALOG_INPUT_0 = 0; // Specify which Analog Input to read.
51 const int MIN_VEL = -10; // Specify Min Velocity.
52 const int MAX_VEL = 10; // Specify Max Velocity.
53 const int ACC = 100; // Specify Acceleration/Deceleration value.
54 const int USER_UNITS = 1048576; // Specify your counts per unit / user units. (the motor used in this sample app has 1048576 encoder pulses per revolution)
55
56 // Initialize RapidCode Objects
57 MotionController controller = MotionController.CreateFromSoftware(/*@"C:\RSI\X.X.X\"*/); // Insert the path location of the RMP.rta (usually the RapidSetup folder)
58 HelperFunctions.CheckErrors(controller); // [Helper Function] Check that the controller has been initialized correctly.
59 HelperFunctions.StartTheNetwork(controller); // [Helper Function] Initialize the network.
60
61 Axis axis = controller.AxisGet(AXIS_NUMBER); // Initialize the axis.
62 HelperFunctions.CheckErrors(axis); // [Helper Function] Check that the axis has been initialized correctly.
63
64 IO ioNode = controller.IOGet(NODE_NUMBER); // Initialize the axis.
65 HelperFunctions.CheckErrors(ioNode); // [Helper Function] Check that the axis has been initialized correctly.
66
67 try
68 {
69 // CONSOLE OUT
70 Console.WriteLine("Velocity Move Initialized.");
71 Console.WriteLine("Max Speed = " + MAX_VEL);
72 Console.WriteLine("Min Speed = " + MIN_VEL);
73 Console.WriteLine("\nPress SPACEBAR to exit.");
74
75 // READY AXIS
76 axis.UserUnitsSet(USER_UNITS); // Specify the counts per Unit.
77 axis.ErrorLimitTriggerValueSet(1); // Specify the position error limit trigger. (Learn more about this on our support page)
78 axis.PositionSet(0); // Make sure motor starts at position 0 everytime.
79 axis.DefaultAccelerationSet(ACC); // Set Acceleration.
80 axis.DefaultDecelerationSet(ACC); // Set Deceleration.
81 axis.Abort(); // If there is any motion happening, abort it.
82 axis.ClearFaults(); // Clear faults.
83 axis.AmpEnableSet(true); // Enable the motor.
84
85 do
86 {
87 while (!Console.KeyAvailable)
88 {
89 velocityAbsoluteSum = Math.Abs(MIN_VEL) + Math.Abs(MAX_VEL);
90 analogCurrentValue = (double)ioNode.AnalogInGet(ANALOG_INPUT_0); // Get analog in value.
91 analogValuePrecentage = analogCurrentValue / analogMaxValue; // Get percentage of analog voltage.
92
93 /*
94 * REPRESENTATION OF ANALOG INPUT VALUE BASED ON DIGITAL OUTPUT VOLTAGE
95 *
96 * AI Value --> 0 ............ 32,769 ............ 65,536
97 * DO Voltage --> 0 ........8 9 10 -10 -9 -8...... 0
98 */
99
100 if (analogValuePrecentage * 100 > 99 || analogValuePrecentage * 100 < 1) // If the Analog Input value is close to 0 or 65,536 then velocity is ZERO.
101 currentVelocity = 0;
102
103 else if (analogValuePrecentage * 100 < 50) // If the Analog Input value is less than 50% of 65,536 then velocity varies from 0 to 10.
104 currentVelocity = velocityAbsoluteSum * analogValuePrecentage;
105
106 else // If the Analog Input value is greater than 50% of 65,536 then velocity varies from 0 to -10.
107 currentVelocity = -velocityAbsoluteSum + (velocityAbsoluteSum * analogValuePrecentage);
108
109 axis.MoveVelocity(currentVelocity); // Update Velocity.
110
111 }
112 } while (Console.ReadKey(true).Key != ConsoleKey.Spacebar); // If the Spacebar key is pressed, exit.
113
114 axis.Abort(); // Abort Motion.
115 }
116 catch (Exception e)
117 {
118 Console.WriteLine(e.Message); // If there are any exceptions/issues this will be printed out.
119 }
121 }
122 }
Definition rsi.h:5870
int32_t AnalogInGet(int32_t analogChannel)
Definition rsi.h:12051
Definition rsi.h:800
