RecordPerformance.cpp
10#include <iomanip>
11
12#include "SampleAppsHelper.h" // Import our helper functions.
13#include "rsi.h" // Import our RapidCode Library.
14
15using namespace RSI::RapidCode; // Import the RapidCode namespace
16
17// Helper function to calculate the minimum, maximum, and average of a vector of integers
18static std::vector<int> MinMaxAvg(std::vector<int> data)
19{
20 int min = data[0];
21 int max = data[0];
22 int sum = 0;
23
24 for (int i = 0; i < data.size(); i++)
25 {
26 if (data[i] < min)
27 {
28 min = data[i];
29 }
30 if (data[i] > max)
31 {
32 max = data[i];
33 }
34 sum += data[i];
35 }
36
37 int avg = sum / data.size();
38 return {min, max, avg};
39}
40
41int main()
42{
43 const std::string SAMPLE_APP_NAME = "Utilities: Record Performance";
44
45 // Print a start message to indicate that the sample app has started
46 SampleAppsHelper::PrintHeader(SAMPLE_APP_NAME);
47
48 /* CONSTANTS */
49 const int RECORD_PERIOD_SAMPLES = 1; // Number of samples between each record.
50 const int RECORD_TIME = 1000; // Time in milliseconds to record for.
51
52 /* RAPIDCODE INITIALIZATION */
53
54 // Create the controller
56 MotionController *controller = MotionController::Create(&params);
57
58 int exitCode = -1; // Set the exit code to an error value.
59 try // Ensure that the controller is deleted if an error occurs.
60 {
62
63 /* SAMPLE APP BODY */
64
65 // Check if the network is started
66 int valuesPerRecord;
67 bool networkTimingEnabled = false;
68 if (controller->NetworkStateGet() != RSINetworkState::RSINetworkStateOPERATIONAL)
69 {
70 std::cout << "Network is not operational. Only Firmware Timing Deltas will be recorded." << std::endl;
71 valuesPerRecord = 1;
72 }
73 else
74 {
75 // Enable network timing
76 controller->NetworkTimingEnableSet(true);
77 networkTimingEnabled = true;
78 valuesPerRecord = 3;
79 }
80
81 // Add a recorder
82 int recorderIndex = controller->RecorderCountGet();
83 controller->RecorderCountSet(recorderIndex + 1);
84
85 // Check if the recorder is running already, if it is then stop it
86 if (controller->RecorderEnabledGet(recorderIndex))
87 {
88 controller->RecorderStop(recorderIndex);
89 controller->RecorderReset(recorderIndex);
90 }
91
92 // Configure the recorder
93 controller->RecorderPeriodSet(RECORD_PERIOD_SAMPLES);
94 controller->RecorderCircularBufferSet(false);
95 controller->RecorderDataCountSet(valuesPerRecord);
96 controller->RecorderDataAddressSet(0, controller->AddressGet(RSIControllerAddressType::RSIControllerAddressTypeFIRMWARE_TIMING_DELTA));
97
98 if (networkTimingEnabled)
99 {
100 controller->RecorderDataAddressSet(1, controller->AddressGet(RSIControllerAddressType::RSIControllerAddressTypeNETWORK_TIMING_DELTA));
101 controller->RecorderDataAddressSet(2, controller->AddressGet(RSIControllerAddressType::RSIControllerAddressTypeNETWORK_TIMING_RECEIVE_DELTA));
102 }
103
104 // Start the recorder
105 controller->RecorderStart(recorderIndex);
106 controller->OS->Sleep(RECORD_TIME);
107 controller->RecorderStop(recorderIndex);
108
109 int recordCount = controller->RecorderRecordCountGet(recorderIndex);
110 std::cout << "There are " << recordCount << " records available." << std::endl;
111
112 // Read the records
113 std::vector<int> firmawareTimingDeltas(recordCount);
114 std::vector<int> networkTimingDeltas(recordCount);
115 std::vector<int> networkTimingReceiveDeltas(recordCount);
116
117 for (int i = 0; i < recordCount; i++)
118 {
119 controller->RecorderRecordDataRetrieve(recorderIndex);
120 firmawareTimingDeltas[i] = controller->RecorderRecordDataValueGet(recorderIndex, 0);
121
122 if (networkTimingEnabled)
123 {
124 networkTimingDeltas[i] = controller->RecorderRecordDataValueGet(recorderIndex, 1);
125 networkTimingReceiveDeltas[i] = controller->RecorderRecordDataValueGet(recorderIndex, 2);
126 }
127 }
128
129 // Calculate the statistics
130 std::vector<int> firmwareTimingStats = MinMaxAvg(firmawareTimingDeltas);
131 std::cout << "Firmware Timing Deltas (us): ";
132 std::cout << " Min = " << std::setw(4) << firmwareTimingStats[0];
133 std::cout << " Max = " << std::setw(4) << firmwareTimingStats[1];
134 std::cout << " Avg = " << std::setw(4) << firmwareTimingStats[2] << std::endl;
135
136 if (networkTimingEnabled)
137 {
138 std::vector<int> networkTimingStats = MinMaxAvg(networkTimingDeltas);
139 std::cout << "Network Timing Deltas (us): ";
140 std::cout << " Min = " << std::setw(4) << networkTimingStats[0];
141 std::cout << " Max = " << std::setw(4) << networkTimingStats[1];
142 std::cout << " Avg = " << std::setw(4) << networkTimingStats[2] << std::endl;
143
144 std::vector<int> networkTimingReceiveStats = MinMaxAvg(networkTimingReceiveDeltas);
145 std::cout << "Network Timing Receive Deltas (us):";
146 std::cout << " Min = " << std::setw(4) << networkTimingReceiveStats[0];
147 std::cout << " Max = " << std::setw(4) << networkTimingReceiveStats[1];
148 std::cout << " Avg = " << std::setw(4) << networkTimingReceiveStats[2] << std::endl;
149 }
150
151 // Delete the recorder
152 controller->RecorderCountSet(recorderIndex);
153
154 exitCode = 0; // Set the exit code to success.
155 }
156 catch (const std::exception &ex)
157 {
158 std::cerr << ex.what() << std::endl;
159 exitCode = -1;
160 }
161 // Delete the controller as the program exits to ensure memory is deallocated in the correct order
162 controller->Delete();
163
164 // Print a message to indicate the sample app has finished and if it was successful or not
165 SampleAppsHelper::PrintFooter(SAMPLE_APP_NAME, exitCode);
166
167 return exitCode;
168}
void RecorderStart()
Start recording data.
void RecorderStop()
void RecorderReset()
int32_t RecorderCountGet()
Get the number of Recorder available in the firmware.
bool RecorderEnabledGet()
Definition rsi.h:795
RapidCodeOS * OS
Definition rsi.h:3697
void NetworkTimingEnableSet(bool enable)
Enable or disable the firmware to start timing the network packets.
Definition rsi.h:856
