10#include "SampleAppsHelper.h"
13#include "RTTasksHelpers.h"
27 const std::string SAMPLE_APP_NAME =
"Real-Time Tasks: Hello RTTasks";
37 std::optional<RTTaskManager> manager;
47 std::cout <<
"Creating task manager..." << std::endl;
55 std::cout <<
"Submitting task..." << std::endl;
58 RTTask task = manager->TaskSubmit(params);
64 std::cout <<
"Getting counter global tag..." << std::endl;
67 if (counter.Int64 <= 0)
71 std::cout <<
"Counter is not greater than 0. The task did not run correctly." << std::endl;
77 std::cout <<
"Counter: " << counter.Int64 << std::endl;
80 catch (
const std::exception& e)
82 std::cerr << e.what() << std::endl;
86 if (manager.has_value())
static RTTaskManager Create(const RTTaskManagerCreationParameters ¶meters)
Create a new RTTaskManager instance.
The RealTimeTasks namespace.
