Motion: Path
Learn how to work with Path motion in C#.
In this page:
📜 Motion: Path
Learn how to set up and run Path Motion 📖 with a Robot object. Shows how to create kinematic models, program path movements using lines and arcs, and execute coordinated multi-axis motion.
/* This sample demonstrates how to set up and run path motion with a Robot object.
using System.Threading;
Console.WriteLine("📜 Motion: Path");
Helpers.VerifyAxisCount(controller, minRequiredSampleAxisCount: 6, minRequiredSampleMultiAxisCount: 1);
// set robot axis labels
// get the 6 axis needed for XYZABC robot
Helpers.CheckErrors(xAxis);
Helpers.CheckErrors(yAxis);
Axis zAxis = controller.AxisGet(Constants.AXIS_2_INDEX);
Helpers.CheckErrors(zAxis);
Axis aAxis = controller.AxisGet(Constants.AXIS_3_INDEX);
Helpers.CheckErrors(aAxis);
Axis bAxis = controller.AxisGet(Constants.AXIS_4_INDEX);
Helpers.CheckErrors(bAxis);
Axis cAxis = controller.AxisGet(Constants.AXIS_5_INDEX);
Helpers.CheckErrors(cAxis);
// configure phantom axes
Helpers.PhantomAxisReset(zAxis);
Helpers.PhantomAxisReset(aAxis);
Helpers.PhantomAxisReset(bAxis);
Helpers.PhantomAxisReset(cAxis);
// set axis labels
xAxis.UserLabelSet(xLabel);
yAxis.UserLabelSet(yLabel);
zAxis.UserLabelSet(zLabel);
aAxis.UserLabelSet(aLabel);
bAxis.UserLabelSet(bLabel);
cAxis.UserLabelSet(cLabel);
// create multi-axis object for joints
int multiAxisMotionSupervisorIndex = controller.AxisCountGet(); // MultiAxis supervisor indices begin after Axis supervisor indices
Axis[] axes = [ xAxis, yAxis, zAxis, aAxis, bAxis, cAxis ];
// create kinematic model with 6-axis configuration
const LinearUnits units = LinearUnits.Meters;
const string modelName = "RSI_XYZABC_Meters";
const double scaling = 1.0;
const double offset = 0.0;
builder.UnitsSet(units);
builder.JointAdd(new LinearJointMapping(3, CartesianAxis.Roll) { ExpectedLabel = aLabel, Scaling = scaling, Offset = offset });
builder.JointAdd(new LinearJointMapping(4, CartesianAxis.Pitch) { ExpectedLabel = bLabel, Scaling = scaling, Offset = offset });
builder.JointAdd(new LinearJointMapping(5, CartesianAxis.Yaw) { ExpectedLabel = cLabel, Scaling = scaling, Offset = offset });
// create Robot object with multi axis and kinematic model
Robot robot = Robot.RobotCreate(controller, jointsMultiAxis, builder, MotionController.AxisFrameBufferSizeDefault);
Helpers.CheckErrors(robot);
// print some robot info
Console.WriteLine($"Robot model: {robot.ModelGet().NameGet()}");
Console.WriteLine($"Robot units: {robot.ModelGet().UnitsGet()}");
// set path motion parameters
robot.PathAccelerationSet(1000); // user units per sec squared
robot.PathVelocitySet(50); // user units per sec
// program path motion
robot.PathProgrammingModeSet(PathMode.Absolute);
robot.PathLine(target: new Pose(1, 1, 1));
robot.PathArc(
target: new Pose(0, 2, 1),
center: new Vector3d(0, 1, 1),
direction: RotationDirection.Clockwise);
// enable amplifiers
jointsMultiAxis.AmpEnableSet(true, Constants.AMP_ENABLE_MS);
// start path motion (non-blocking)
robot.Run();
// monitor motion
while (robot.IsRunning())
Thread.Sleep(100);
Pose currPose = robot.CommandPoseGet();
Vector3d currPosition = currPose.Position;
// This move has no orientation change, so printing ABC is unnecessary
Console.WriteLine($"Current pose is (X ={currPosition.X,5:N2}, Y ={currPosition.Y,5:N2}, Z ={currPosition.Z,5:N2})");
jointsMultiAxis.AxisRemoveAll();
const int AXIS_5_INDEX
Default: 5.
Definition _constants.cs:25
const int AXIS_3_INDEX
Default: 3.
Definition _constants.cs:23
const int AXIS_4_INDEX
Default: 4.
Definition _constants.cs:24
const int AXIS_1_INDEX
Definition _constants.cs:21
const int AXIS_2_INDEX
Default: 2.
Definition _constants.cs:22
Definition rsi.h:860
void AxisRemoveAll()
Definition rsi.h:12226
📜 Motion: Path Gantry
Learn how to set up a kinematic model with a gantry prime axis for Path Motion 📖 . Shows how to configure a 1:1 geared axis system where two physical axes work together.
/* This sample demonstrates how to set up a kinematic model with a gantry prime axis.
to control the same cartesian coordinate.
Console.WriteLine("📜 Motion: Path Gantry");
const string yPrimeLabel = "Y-Prime";
// get the 3 axis needed for XY_Yp robot
Axis primeAxis = controller.AxisGet(Constants.AXIS_2_INDEX);
Helpers.CheckErrors(primeAxis);
Helpers.PhantomAxisReset(primeAxis);
// set the expected labels for each axis
primeAxis.UserLabelSet(yPrimeLabel);
// the joint index of each axis is the index within the MultiAxis object
// "X-Axis" has joint index 0
// "Y-Axis" has joint index 1
// "Y-Prime" has joint index 2
Axis[] axes = [xAxis, yAxis, primeAxis];
const LinearUnits units = LinearUnits.Millimeters;
const string modelName = "RSI_XY_Yp";
builder.JointAdd(new LinearJointMapping(2, CartesianAxis.Y) { ExpectedLabel = yPrimeLabel, Scaling = scaling, Offset = offset });
// create Robot object where the y and y prime will be geared 1:1
const int motionFrameBufferSize = 50; // this is the minimum valid motion frame buffer size
Robot robot = Robot.RobotCreate(controller, jointsMultiAxis, builder, motionFrameBufferSize);
Console.WriteLine($"Model name: {robot.ModelGet().NameGet()}");
Console.WriteLine($"Model units: {robot.ModelGet().UnitsGet()}");
Console.WriteLine("Gantry configuration: Y-axis and Y-Prime axis are geared 1:1");
📜 Motion: Path 3D Rendering
Learn how to get 3D path points for rendering visualization from Path Motion 📖 . Shows how to retrieve planned positions for use with 3D graphics libraries.
/* This sample demonstrates how to get 3D path points for rendering visualization.
Shows how to retrieve planned positions from a Robot path for use with 3D graphics libraries
or visualization tools.
Console.WriteLine("📜 Motion: Path 3D Rendering");
// get the 3 axis needed for XYZ robot
// set axis labels
Axis[] axes = [xAxis, yAxis, zAxis];
// create simple 3-axis kinematic model
const string modelName = "RSI_XYZ";
builder.UnitsSet(LinearUnits.Millimeters);
robot.PathAccelerationSet(100);
robot.PathArc(
// process the path to build trajectory
robot.PathProcessLoadedMoves();
// get path points for 3D rendering
Console.WriteLine("Retrieving 3D path points for rendering:");
const ulong frameCount = 500;
ulong startFrame = 0;
int totalPointCount = 0;
ulong retrievedFrames;
do
RapidVectorRobotPosition positions = robot.PathPlannedPositionsGet(startFrame, frameCount);
retrievedFrames = positions.Size();
foreach (RobotPosition position in positions.ToArray())
Vector3d spatial = position.Pose.Position;
// print every 100th point as an example
if (totalPointCount % 100 == 0)
Console.WriteLine($"Point {totalPointCount,3}: X={spatial.X,5:F2}, Y={spatial.Y,5:F2}, Z={spatial.Z,5:F2}");
totalPointCount++;
// add code here to create rendering with your preferred 3D library
// examples:
// vector3 = new Vector3D(spatial.X, spatial.Y, spatial.Z);
// linePositions.Add(vector3);
// scene.AddPoint(spatial.X, spatial.Y, spatial.Z);
startFrame += retrievedFrames;
while (retrievedFrames == frameCount);
// print total points retrieved
Console.WriteLine($"Total 3D points retrieved: {totalPointCount}");
