Motion: Gearing
Learn how to configure Gearing coordinated motion between axes in C#.
In this page:
📜 Gearing Motion
Learn how to configure electronic Gearing 📖 between two axes. The follower axis follows the moving axis at a specified gear ratio (numerator/denominator). Shows how to set up a 2:1 gear ratio where the follower rotates twice for each rotation of the moving axis.
/* This sample demonstrates how to configure electronic gearing between two axes.
The follower axis position is controlled as a ratio of the moving axis position.
Moving Axis: the master axis that drives the motion.
Follower Axis: follows the moving axis at a specified gear ratio.
See the Gearing concept page (Concepts > Motion > Gearing) for how the follower's command is formed
and how moves and stopping actions on the follower behave.
Console.WriteLine("📜 Gearing");
const int NUMERATOR = 2; // for every 1 rotation of moving axis...
const int DENOMINATOR = 1; // ...follower axis rotates 2 times (2:1 ratio)
const double POSITION = 10;
const double VELOCITY = 10;
const double ACCELERATION = 100;
const double DECELERATION = 100;
// get axes
Axis movingAxis = controller.AxisGet(Constants.AXIS_0_INDEX);
Axis followerAxis = controller.AxisGet(Constants.AXIS_1_INDEX);
// configure phantom axes
// enable phantoms to keep commanded position after motion done
followerAxis.AmpEnableSet(true, Constants.AMP_ENABLE_MS);
// configure follower axis to gear to moving axis
followerAxis.GearingEnable(
masterAxisNumber: movingAxis.NumberGet(),
masterFeedbackSource: RSIAxisMasterType.RSIAxisMasterTypeAXIS_COMMAND_POSITION, // use COMMAND for phantoms, ACTUAL for real axis
numerator: NUMERATOR,
denominator: DENOMINATOR);
// perform s-curve motion on moving axis
movingAxis.MoveSCurve(POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT);
movingAxis.MotionDoneWait();
// print results
Console.WriteLine($"Moving axis final position: {movingAxis.CommandPositionGet()}");
Console.WriteLine($"Follower axis final position: {followerAxis.CommandPositionGet()}");
Console.WriteLine($"Gear ratio: {NUMERATOR}:{DENOMINATOR}");
// disable gearing
followerAxis.GearingDisable();
const int AXIS_1_INDEX
Definition _constants.cs:21
void GearingDisable()
Disable the electronic gearing.
void GearingEnable(int32_t masterAxisNumber, RSIAxisMasterType masterFeedbackSource, int32_t numerator, int32_t denominator)
int32_t NumberGet()
Get the axis number.
RSIAxisMasterType
Definition rsienums.h:1359
