Axis: Hardware Limits
Controller Interrupts sample application.
There are four configurations available for a motor's positive and negative hardware limit inputs: 1) Event Action (action such as RSIActionE_STOP, RSIActionNONE, etc...) 2) Event Trigger (trigger polarity such as active HIGH and active LOW) 3) Direction Flag ("ENABLED" will cause the command direction of motion to qualify the events, "DISABLED" will ignore direction, based solely on the limit input state) 4) Duration (the limit condition will exist for a programmable number of seconds before an event occurs)
Precondition
#include "SampleApps.h"
int HardwareLimits::Run()
/* CONSTANTS */
const double USER_UNITS = 1048576; // Specify your counts per unit / user units. (the motor used in this example has 1048576 encoder pulses per revolution)
// Hardware Limit configuration parameters
const bool ACTIVE_HIGH = true; // Constant for active high.
const bool ACTIVE_LOW = false; // Constant for active low.
const double HW_POS_DURATION_TIME = 0.01; // Positive limit duration. (in seconds)
const double HW_NEG_DURATION_TIME = 0.01; // Negative limit duration. (in seconds)
USE_HARDWARE = false;
const std::string rmpPath = "C:\\RSI\\X.X.X\\"; // Insert the path location of the RMP.rta (usually the RapidSetup folder)
/* SAMPLE APP BODY */
MotionController* controller = MotionController::CreateFromSoftware(/*rmpPath*/); // NOTICE: Uncomment "rmpPath" if project directory is different than rapid setup directory.
if (USE_HARDWARE)
printf("Hardware Limits Example\n");
// Change Hardware POSITIVE (+) Limit characteristicpp.
axis->HardwarePosLimitActionSet(RSIAction::RSIActionE_STOP); // Set the positive limit action to E_STOP.
printf("\nHardware Positive Limit Action set to %i", axis->HardwarePosLimitActionGet());
axis->HardwarePosLimitTriggerStateSet(ACTIVE_HIGH); // Set the positive limit trigger state to ACTIVE_HIGH.
printf("\nHardware Positive Limit TriggerState set to %i", axis->HardwarePosLimitTriggerStateGet());
axis->HardwarePosLimitDurationSet(HW_POS_DURATION_TIME); // Set the positive limit duration to 0.01 seconds.
printf("\nHardware Positive Limit Duration set to %f seconds", axis->HardwarePosLimitDurationGet());
// Change Hardware NEGATIVE (-) Limit charateristicpp.
axis->HardwareNegLimitActionSet(RSIAction::RSIActionE_STOP); // Set the negative limit action to E_STOP.
printf("\nHardware Negative Limit Action set to %i", axis->HardwareNegLimitActionGet());
axis->HardwareNegLimitTriggerStateSet(ACTIVE_LOW); // Set the negative limit trigger state to ACTIVE_LOW.
printf("\nHardware Negative Limit TriggerState set to %i", axis->HardwareNegLimitTriggerStateGet());
axis->HardwareNegLimitDurationSet(HW_NEG_DURATION_TIME); // Set the negative limit duration to 0.01 seconds.
printf("\nHardware Negative Limit Duration set to %f seconds", axis->HardwareNegLimitDurationGet());
printf("\nAll Hardware Limit characteristicpp set\n");
catch (RsiError const& err)
printf("\n%s\n", err.text);
return -1;
return 0;
sets the trigger state.
trigger state return.
Trigger state return.
Sets the trigger state.
Definition rsi.h:111
@ RSIActionE_STOP
Definition rsienums.h:1259
