RsiError
Represents the error details thrown as an exception by all RapidCode classes. This class contains an error number/type, RSIErrorMessage, and a text message which describes the error. Throwing exceptions can be disabled on all RSI classes. If throwing exceptions is disabled, a log of RsiErrors can be accessed. Inherits from std::exception in C++ and System.Exception in C#. More...
Functions
 RsiError (const RsiError &copyFrom)
 Copy constructor for RsiError.
const char * what () const noexcept
Attributes
char fileName [RSI_ERROR_TEXT_SIZE]
 source file name
char functionName [RSI_ERROR_TEXT_SIZE]
 Function name of the raised the error.
bool isWarning
int32_t lineNumber
 Source code line number.
RSIErrorMessage number
 Error number.
int32_t objectIndex
 Object index (0-based index of the object that has the error).
char shortText [RSI_ERROR_TEXT_SIZE]
 Error short text.
Static Attributes
static constexpr uint32_t RSI_ERROR_TEXT_SIZE = 512U
 Error message text.
Description
RSIErrors are thrown from RapidCode API calls and provide useful information for diagnostics and debugging. Objects and all data members are created on the stack and the RsiError object itself is thrown. The preferred catch is by const reference, but by value will work, too. It is safe to assume that every RapidCode API call can throw an RsiError.
Exception throwing can be disabled for an object instance using RapidCodeObject::ThrowExceptions(false) and enabled using RapidCodeObject::ThrowExceptions(true). It can be disabled across then entire API by calling this function on the MotionController instance if set to false, a log of RsiErrors can be accessed using RapidCodeObject::ErrorLogGet()
Our destructors do NOT have a nothrow guarantee. If this occurs, please provide a reproducible snippet to RSI.
// something that throws an RsiError()
catch (const RSI::RapidCode::RsiError &rsi_error)
rsi_error.number;
rsi_error.lineNumber;
rsi_error.objectIndex;
rsi_error.isWarning;
rsi_error.text;
rsi_error.functionName;
rsi_error.shortText;
rsi_error.what();
Definition rsi.h:105
bool isWarning
Definition rsi.h:114
Definition rsi.h:167
char shortText[RSI_ERROR_TEXT_SIZE]
Error short text.
Definition rsi.h:121
int32_t lineNumber
Definition rsi.h:110
char functionName[RSI_ERROR_TEXT_SIZE]
Definition rsi.h:119
Error number.
Definition rsi.h:108
int32_t objectIndex
Definition rsi.h:112
ControllerInterrupts.cpp, HardwareLimits.cpp, HelperFunctions.cs, Memory.cpp, MotionHoldReleasedBySoftwareAddress.cpp, MultiaxisMotion.cpp, PVTmotionMultiAxis.cpp, PathMotion.cpp, SampleAppsHelper.h, SingleAxisSyncOutputs.cpp, StreamingMotionBufferManagement.cpp, SyncOutputWithMotion.cpp, Template.cpp, UpdateBufferPoints.cpp, and UserLimitDigitalInputAction.cpp.
Definition at line 104 of file rsi.h.
