◆ InterruptEnableSet()
void InterruptEnableSet ( bool enable)
InterruptEnableSet - If true, this controller will generate interrupts. If false, the controller will not generate interrupts.
enableTrue = interrupts are enabled.
IO: User Limits
// configure user limits
Helpers.CheckErrors(input0);
Helpers.CheckErrors(output0);
output0.Set(false);
number: 0,
conditionNumber: 0,
number: 0,
actionAxis: 0,
duration: 0);
number: 0,
enabled: true);
if (output0.Get())
if (!output0.Get())
output0.Set(false);
void Set(bool state)
bool Get()
Definition rsi.h:12773
RSIEventType
Event Types or Status Bits.
Definition rsienums.h:1102
RSIUserLimitLogic
Definition rsienums.h:771
Definition rsienums.h:1256
Trigger types for UserLimits.
Definition rsienums.h:758
This will buffer Interrupts from Axes & MultiAxes too. It may appear you have a memory leak if you have this enabled and aren't using InterruptWait sufficiently to empty the growing buffer.
InterruptWait
