| void CompensatorConfigSet | ( | int32_t | compensatorNumber, |
| int32_t | firstInputAxisNumber, | ||
| RSIAxisMasterType | firstInputAxisType, | ||
| double | firstInputAxisMinimum, | ||
| double | firstInputAxisMaximum, | ||
| double | firstInputAxisDelta, | ||
| int32_t | secondInputAxisNumber, | ||
| RSIAxisMasterType | secondInputAxisType, | ||
| double | secondInputAxisMinimum, | ||
| double | secondInputAxisMaximum, | ||
| double | secondInputAxisDelta, | ||
| int32_t | outputAxisNumber, | ||
| RSICompensatorOutputType | outputType, | ||
| const double *const | table ) |
| compensatorNumber | which compensator to configure? |
| firstInputAxisNumber | This specifies the axis of the first compensating Axis object. The position from this Axis will be used to index a single dimension of the compensation table. This number must correspond to a valid (existing) and enabled Axis on the controller. |
| firstInputAxisType | |
| firstInputAxisMinimum | The minimum feedback position (COUNTS) along the first compensation axis where compensation will occur. |
| firstInputAxisMaximum | The maximum feedback position (COUNTS) along the first compensation axis where compensation will occur. |
| firstInputAxisDelta | Spacing between compensation positions on the compensating axis. positionDelta must meet some specifications: positionDelta must be an exact multiple of the range (i.e. ((range.positionMax - range.positionMin) / positionDelta) must be an integer value). positionDelta must be greater than zero. positionDelta must be greater than (positionMax - positionMin). |
| secondInputAxisType | |
| secondInputAxisNumber | This specifies the axis number of the second compensating Axis object. The position from this Axis will be used to index a single dimension of the compensation table. This number must correspond to a valid (existing) and enabled Axis on the controller. |
| secondInputAxisMinimum | The minimum feedback position (COUNTS) along the second compensation axis where compensation will occur. |
| secondInputAxisMaximum | The maximum feedback position (COUNTS) along the second compensation axis where compensation will occur. |
| secondInputAxisDelta | Spacing between compensation positions on the secondcompensating axis. positionDelta must meet some specifications: positionDelta must be an exact multiple of the range (i.e. ((range.positionMax – range.positionMin) / positionDelta) must be an integer value). positionDelta must be greater than zero. positionDelta must be greater than (positionMax - positionMin). |
| outputAxisNumber | This specifies the axis of the Axis to be compensated by the Compensator object. This number must correspond to a valid (existing) and enabled Axis on the controller. |
| outputType | Sets the behavior of a compensator. SINGLE: Only the most recent compensator configured to output on a specific axes will be applied ADDITIVE: The output of the compensator will be added with the result form the previously applied compensator on the specific axis. |
| table | the points which will be written to the table |
