◆ RecorderEnabledGet()
bool RecorderEnabledGet ( )
RecorderEnabledGet determines if the recorder is recording.
(bool) True = recorder is recording, false = not recording.
Recorder
using NUnit.Framework;
using System;
#endif
[Test]
public void Recorder()
const int INPUT_INDEX = 0;
controller.AxisCountSet(1);
Definition rsi.h:5526
Definition rsi.h:10941
void RecorderStart()
Start recording data.
void RecorderStop()
void RecorderReset()
bool RecorderEnabledGet()
RapidCodeOS * OS
Definition rsi.h:3673
Definition rsienums.h:404
Definition rsienums.h:433
RecorderStop
RecordPerformance.cpp, and Recorder.cs.
